What NEXT???? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-08-2013, 01:42 PM Thread Starter
powerstroke_steve's Avatar
What NEXT????
So I have a 2004 f250 6.0 CC SB and it now has 40K original miles. I recently installed a 4" MBRP exhaust And an AFE stage 2 intake. Now i want to start modding it some more but don't know what to do next. keep in mind its not bulletproofed, but i want to hear everyone's suggestions/opinions.
U Mad Bro???
powerstroke_steve is offline
post #2 of 14 Old 05-08-2013, 01:52 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Sct tuner with custom tunes from matt@gearhead and if you ever blow the studs put some arp with oem gaskets
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 14 Old 05-08-2013, 02:07 PM Thread Starter
should i do the studs and all the bulletproofing stuff before i tune it?
U Mad Bro???
post #4 of 14 Old 05-08-2013, 02:14 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
It depends on what your goals with the truck are. I would
Oliver
ODAWG714 is offline
post #5 of 14 Old 05-08-2013, 02:23 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
If I were you I would do the following in order
1. Coolant filter
2 studs
3 egr delete or block the egr cooler and. Put a solid up pipe
4 sct tuned by gear head
5 ported intake manifold
6 regulated return
Oliver
ODAWG714 is offline
post #6 of 14 Old 05-08-2013, 02:43 PM Thread Starter
ok so what filter do you recommend.
U Mad Bro???
post #7 of 14 Old 05-08-2013, 02:59 PM
*nothing wrong with headbolts i have proved that time and time again. Now if you are planning to drag the truck or any extreme running conditions then you want to stud first
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 14 Old 05-08-2013, 02:59 PM
just buy a cheap one, sinister etc etc. The IPR is the cadillac of coolant filters though
bpd
Warren comp trans
04cr450 is offline
post #9 of 14 Old 05-08-2013, 03:07 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
WHS^^
If you want the piece n mind of head studs then go for it
Oliver
ODAWG714 is offline
post #10 of 14 Old 05-08-2013, 06:11 PM
Bderick67's Avatar
Do you have gauges or a scanner to monitor the vital parameters of the engine?
Brian
early 2004 F250 CC SB Lariat FX4
* with BPD Oil Cooler/cold weather pack * BPD EGR Cooler * Scangauge II * Blue spring update * Blue wire fan mod *
* Rotella T6 w/ Archoil 9100 * 4" catback exhaust w/5" tip
* 63,5xx miles *
Bderick67 is offline
