Trans acting funny.. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-08-2013, 09:17 AM Thread Starter
colinmitchell111's Avatar
The other day I laid into it from a 25 mph roll broke the tires loose a bit then pulled hard up to 75 mph. When I backed out of it to hold steady speed I looked at the tach and I was at 3800 rpm! Looked at the cts and I was in 4th gear unlocked. I played with the throttle for about 10 seconds and it wouldn't shift. I then hit the tow/haul button with my foot on the gas and it went to neutral and I reved it to 4500 on accident when I backed out of it I shut the tow haul off and it found a gear and has been fine since. Any ideas? Mods in my sig I've been running looney for about a year and it has been awesome thats why I don't think this would be a tuning issue..
04 F250 SC SB auto 4x4
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
Sinister coolant filter kit
Upgraded blue FPR spring
CCV Dump
Warn locking hubs
SCT with Looney
colinmitchell111 is offline
post #2 of 5 Old 05-08-2013, 09:26 AM
portcity_gt's Avatar
Quoted: 1270 Post(s)
They act stupid like that sometimes. It could be one of the soliniods sticking or going out.
If I remember right the cts only counts shifts not displays commanded shift, so it was more than likely a problem with the 3-5 shift not fourth as the trucks rarely use fourth.
A modified direct drive soliniod or a epc soliniod inplace of the direct drive will help.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #3 of 5 Old 05-08-2013, 09:37 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i had similar issues till i replaced the direct drive solenoid. you can replace it with a custom EPC solenoid if you prefer. msg me if you have further questions about replacement.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 5 Old 05-09-2013, 12:43 AM Thread Starter
Thanks guys.
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #5 of 5 Old 05-09-2013, 05:42 AM
colonel angus's Avatar
Quoted: 2 Post(s)
The Solenoid swap is easy, but the "WYIT" while your in there's can get ya for about 240....
08 Pan upgrade and internal filter.
EPC Sol. 85.00
New Fluid 90.00
Frame TP Filter 30.00
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
