Fuel PSI: Tune Specific - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-08-2013, 06:54 AM Thread Starter
pcris's Avatar
I tried a quick search for any threads specific to this and came up with none so figured I'd start a discussion to find some answers for curiousity.
After installing my fuel psi gauge a while back, I gave looney a try from Vivian as I have only run SRL as my daily since owning the truck. I noticed a slight fuel psi drop when I loaded looney (~58psi). I was slightly concerned since it wasnt up to what it had been but after I went back to SRL, my fuel psi idles around 63psi.
My question is, I'm not familiar enough with tuning to know, if the fuel psi is related to the tuning and power output or just slightly different parameters in tuning result in slightly different pressures. Now I know you don't just increase pressure for power, but I was just curious because I feel my srl has more juice than looney and it runs higher pressure. Again, just curious if all this is related or just a parameter in the tuning that differs between tuners?
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
Blue Spring | FP Gauge
PMM Coolant Filter
Leveled|35's
LED Reverse|Bed Rails
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #2 of 9 Old 05-08-2013, 07:12 AM
DoubleDpsd's Avatar
Fuel psi really only matters on a wot run. 63 at idle is fine. 45 at idle isnt. Idle isnt the true test of fuel psi. Wot run from dead stop or lugging up a hill tc locked going about 60mph put it to the floor that's another way to test psi drop. Obviously a larger demand on pump with a tune.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 9 Old 05-08-2013, 07:55 AM
snafu!'s Avatar
Fuel pressure at idle shouldn't change from one tune to the next, FP is controlled mechanically (spring). FP may differ at wot like said before on different tunes. I know Matt tries to produce the least amount of smoke so his tune my not fuel as hard at wot vs Looney. Fuel pressure around 50-55 will give you the most HP and torque.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #4 of 9 Old 05-08-2013, 09:27 AM Thread Starter
pcris's Avatar
Thats weird though, because like you said, it is mechanical, but when running looney, it would never go over 60 at idle with srl at 63 at idle. WOT on both tunes they drop about the same, mid-low 50's.
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
PMM Coolant Filter
Leveled|35's
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #5 of 9 Old 05-08-2013, 10:12 AM
DoubleDpsd's Avatar
You're fine.
post #6 of 9 Old 05-08-2013, 10:52 AM Thread Starter
pcris's Avatar
Originally Posted by DoubleDpsd View Post
You're fine.
Ya I know I am fine, I was just stating the fact I see different pressures through different tunes, not questioning if they are too low
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
PMM Coolant Filter
Leveled|35's
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #7 of 9 Old 05-08-2013, 11:47 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 9 Post(s)
Feedback Score: 3 reviews
FWIW, my FP don't change with any tunes, race or tow.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is online now
post #8 of 9 Old 05-08-2013, 12:13 PM
agreed^ I run srl tune and my FP doesnt drop below 62 psi with blue spring in it at WOT. You need a fuel pump soon.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #9 of 9 Old 05-09-2013, 07:00 AM
I've noticed a slight decrease in psi from IDP's tunes to Wildman's, Mainly from my tow tune to race tune
With my 190's Ill go from 60psi to abouit 52psi wot..
2005 Lariat 6.0
4" TB exhaust to 6" tip
Tuned by the Wildman
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
Blackcloud413 is offline
