Finally installed my intake manifold! - Ford Powerstroke Diesel Forum
post #1 of 41 Old 05-07-2013, 09:08 PM Thread Starter
1fastTRX's Avatar
Well I finally got around to installing my ported intake manifold that ODAWG714 (Oliver) made for me. After his fiasco with a subpar manifold made by Soot Powered (Do not buy from them) he tore the manifold open and "worked" it himself. I decided to paint it black. I didn't get too fancy. I'm not trying to raise any flags (california )
If anybody goes to install a ported manifold I'll offer some tips to hopefully save some people headache and money...
COVER ANY OIL RELATED HOLES!!!!!!!! Once you get the turbo off and have view/access to the original manifold use compressed air to blow any junk away from the ports so nothing can fall into the head. We cleaned the valley and didn't cover the oil filter housing... well I didn't do that and unfortunately caused the IPR to crap out. $200 later I had a replacement valve and screen.
When removing injector clips don't pull the clips, because they can and will fly away. Instead push the flat part of the clip inward and the harness will pull off. If you pushed it far enough the harness will easily pull off.
Oliver helped me with the removal/install along with another buddy who's a Ford tech (hence where I learned the injector harness clip trick).
On to the good stuff:
Once the truck was all back together with a new IPR valve I went for a drive (120 miles lol). The truck completely feels lighter on its feet. Less effort to get it moving. Cruising EGT's are down about 50-100 degrees. I had cruise control set at 80 mph on a stretch of flat freeway and EGT's were 700 (before manifold was about 800-850). In the same area, but the opposite direction EGT's were about 750. I slowed down to 65 mph and EGT's were 600-650 (before manifold were about 675-750). On WOT runs the EGT's
climbed much slower than before. Simply passing a car seems more effortless and EGT's dont hit 1,000+ degrees doing it. The turbo lights WAY faster than
before too. I noticed the hybrid was more sluggish to build boost vs the stage 1 which I always wondered about, but now it spools and just starts moving! The truck seems to sound quieter, but that could be my ears deceiving me. The lie-o-meter shows about 1 mpg improvement which includes all my WOT runs, but I take that with a grain of salt. I'll fill my tank up and hand calculate the numbers and update the thread later with those numbers. Don't hold your breath for that one though, because I don't daily drive the truck. LOL.
I'm not a dyno guy so I'll go to the track (sorry only 1/8th mile around here) and get some numbers. If my mph is a decent amount higher than 73mph (stock turbo stock manifold) then I may install the stock turbo to see how much just the manifold is doing for the truck. I'm really enjoying how the truck is running now. I liked it before, but even moreso now. Injectors were in my future, but honestly I'm just going to enjoy my truck.
I have some videos I took of some of the runs. I combined them to a single youtube video:
The EGT video where it slowly goes to 1300 then back down to 1200 I was still WOT when it dropped off to 1200. I let off after it backed down to 1200
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #2 of 41 Old 05-07-2013, 09:31 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Nice review Logan! I'm glad your truck is back to life lol. And me n mig had nothing to do with cleaning the valley that was all you lmao.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is online now
post #3 of 41 Old 05-07-2013, 09:37 PM Thread Starter
1fastTRX's Avatar
Edited just for you.
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #4 of 41 Old 05-07-2013, 09:38 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
Giving u grief lol regulated return now!!
Next week ill have two more made, my second one and mikes. I think he's convinced now
Oliver
post #5 of 41 Old 05-08-2013, 03:12 AM
bondajb's Avatar
very nice... thanks for the tips Dawg
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #6 of 41 Old 05-08-2013, 03:34 AM
damn that thing will bury the speedo in a hurry. truck sounds great from inside.
2006 F250 CCSB LARIAT FX4
studs, oil cooler, egr delete, 4"exhaust SCT, Wicked Wheel
streetdemon70 is offline
post #7 of 41 Old 05-08-2013, 05:21 AM
that truck straight gets up and moves! awesome.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 41 Old 05-08-2013, 06:22 AM Thread Starter
1fastTRX's Avatar
Here's a picture of what the inside looked like while Oliver was working on it.
For being as big of a truck (CCLB) as it is I think it moves out pretty good
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #9 of 41 Old 05-08-2013, 06:38 AM
snafu!'s Avatar
The inside of your intake looks really good, impressive work Odawg.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #10 of 41 Old 05-08-2013, 07:21 AM
ODAWG714's Avatar
Quoted: 6 Post(s)
Thx brotha here's a before
After machining and a little blast looks like this
Oliver
