low fuel pressure - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-07-2013, 01:53 PM Thread Starter
01redcrew's Avatar
Quoted: 2 Post(s)
low fuel pressure
hey guys,
Here lately my fuel pressure is getting low at idle and hard acceleration, im thinking my factory fuel pump is getting weak.
I have the blue spring mod and my fuel filters have only about 5k on them, thats what leads to think my factory pump is getting weak.
What are your guys thoughs. My fuel pressure is between 62-64 and use to hold strong at 68 at idle
Thanks for the help guys Brad
2013 6.7 with stuff
01redcrew is offline
post #2 of 13 Old 05-07-2013, 02:02 PM
JGman141's Avatar
It sounds like the pump is on it's way out but I could also be that the fuel filters are getting clogged. I would replace the filters first before doing the pump.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 13 Old 05-07-2013, 07:30 PM Thread Starter
01redcrew's Avatar
Quoted: 2 Post(s)
what's everyone else think?
2013 6.7 with stuff
post #4 of 13 Old 05-07-2013, 07:47 PM
pump for sure. Mine did that then went as low as 20 psi
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 13 Old 05-07-2013, 09:17 PM
1fastTRX's Avatar
What's it drop off to at WOT?
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #6 of 13 Old 05-08-2013, 05:37 AM Thread Starter
01redcrew's Avatar
Quoted: 2 Post(s)
Around 30 for a spilt second than maybe jump back to 50psi
2013 6.7 with stuff
post #7 of 13 Old 05-08-2013, 06:18 AM
1fastTRX's Avatar
I would say replace it. Better to replace the pump now than replace injectors later. Don't get an AirDog 2
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #8 of 13 Old 05-08-2013, 02:19 PM Thread Starter
01redcrew's Avatar
Quoted: 2 Post(s)
When I replace should i go with a factory motocraft pump. Or is there better aftermarket pumps out?
2013 6.7 with stuff
post #9 of 13 Old 05-08-2013, 03:02 PM
I went with a whole new ford hfcm assembly- tousely ford cant beat it.
bpd
Warren comp trans
04cr450 is offline
post #10 of 13 Old 05-08-2013, 03:04 PM
heeeeyyy I havnt been paying attention but.. You kept your truck! good man
bpd
Warren comp trans
04cr450 is offline
