turbo boost gauge - Ford Powerstroke Diesel Forum
Old 02-26-2008, 10:42 AM
turbo boost gauge
Need some help... Where do you hook up the turbo boost gauge. I have the hose and the "T" but where does it go?? Help
Old 02-26-2008, 10:47 AM
Send a message via AIM to 4everlearning
goes into the intake elbo.
Old 02-26-2008, 10:48 AM
So I have to drill a hole in the elbow?
Old 02-26-2008, 11:01 AM
If you want an accurate reading, yes.
Old 02-26-2008, 11:09 AM
I guess I'll get a new elbow with the hole already in it. Any votes on which is the best.
Old 02-26-2008, 11:19 AM
Drilling the intake elbow it very easy, no need to spend $100 on a elbow with holes in it already. To take the elbow off you just need to take the hose clamp off and remove the 4 10mm bolts. Then use a 21/64 drill bit and a 1/4 npt tap. Should take about 15 minutes including taking it off the truck and putting it back on.
Old 02-26-2008, 11:24 AM
say no to rolling coal
I'll second this... It really is very easy and the most you'll need to buy is a $2.50 tap instead of $150 elbow... Just take your time drilling and running the tap in and you'll be fine.
Old 02-26-2008, 11:34 AM
I wanna go fast!!!
is the 1/4 tap the same for all the brands of boost gauges?
Old 02-26-2008, 11:41 AM
Thank y'all I will do that... The Boss will like the less expensive alternative...
Old 02-26-2008, 12:59 PM
why dont you just tap into the map sensor with a vacum tee its bolted to the top part of the a/c box on pass. side has wire loom around it makes it look like wiring but its the vacum line goes to the intake less than 1ft away i just cut mine put in the tee with a little silicone for insurance no drilling required
