bat-mo-wheel,,,,wicked wheel - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-07-2013, 12:31 PM Thread Starter
rogerallen33's Avatar
I was just wondering about the batmowheel and wicked wheel, my truck is a early 04, so it has the 03 motor and turbo, that whistles, im thinking about having one of this installed, which is best,,,, and I was wondering if anyone out their has one on a 03 turbo, do you still have your whistle,,, I don't wanna lose my whistle for a couple more hp,
rogerallen33 is offline
post #2 of 7 Old 05-07-2013, 12:47 PM
JGman141's Avatar
You won't lose the whistle because that comes from the turbine side.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 7 Old 05-07-2013, 12:55 PM
portcity_gt's Avatar
Quoted: 1268 Post(s)
No change in whistle......and most will say there's no comparison with those two wheels. Wicked wheel will be the better of the two. Also look into mad turbo werks they're active on this site and have great products and service.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 7 Old 05-07-2013, 02:37 PM
turbotibbo's Avatar
I have a mtw wheel for my 03 turbo and so far I love it , power increase and lower egts along with a bit less lag
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #5 of 7 Old 05-07-2013, 06:08 PM Thread Starter
what does your truck idle at with that high idle mod,, I use my sct to increase my idle,,, I have it set at 775, and I have notice much quick take offs,
post #6 of 7 Old 05-07-2013, 07:35 PM
turbotibbo's Avatar
It idles at 1200 rpm but u can only use it when the park brake is set
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #7 of 7 Old 05-07-2013, 07:58 PM
Chanzfx4's Avatar
Feedback Score: 3 reviews
Does this mod justify the cash and time to replace? I have about it but just can't see it.
2003 White F350 Fx4 CC SWR
Go Fasts:
X2 tuned with SRL+
4 Inch Open Dp
Egr Delete
Blue Spring Mod
Riff Raff Boots
Sinister Coolant Filter
All Aluminum Radiator
ZooDad
Looks:
Blacked Tails
285/75/16 Destination M/Ts
Camo Interior
Leveled
Raised Black Nerf Bars
Black Bed Rails
Chanzfx4 is offline
