Most reliable fuel system - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 05-07-2013, 11:11 AM Thread Starter
I am currently making a parts list for my truck that I'm replacing the engine in starting sometime this week, already have some things on the list but cannot determine a decent fuel system. I've heard all bad things about bass and ad. Anybody have ideas or advice
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #2 of 12 Old 05-07-2013, 12:07 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
ILL BE THE FIRST!! no airdog!!! anything else but!! Im sure there great on low pressure aplications but that is it!!!
Some of the guys here have made there own including me but im going to let the guys running fass and other brands chim in!!!
let the party begin!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #3 of 12 Old 05-07-2013, 12:29 PM
Heath_R's Avatar
If I had to do it over again I would feed the rear of the heads and pull the returns from the front--just think it would be a lot cleaner looking. I have a a-1000 with XDP sump through some napa filter bases up to the engine in -10 pushloc and then switched over to braided in the engine bay.
[IMG] 2012-10-25 13.35.29 by Heath_Runkles, on Flickr[/IMG]
2005 250 CCSB --- ARP's -- Regulated return --- 4" turbo back MBRP --- NUC oil bypass --- Sinister coolant filter ---PHP FICM tuner--- modded DD solenoid --- 08+ trans pan and filter-- Warren 175\30--a1000 fuel with rr\xdp sump
Heath_R is offline
post #4 of 12 Old 05-07-2013, 02:13 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I have heard this phrase so many times that I forget and for the life of me, I just don't get what is so "dirty" (for lack of a better description) about feeding heads from the front of the motor.
I built my own fuel system from the tank to the motor and back and I have absolutely no desire to feed my heads from the back of the motor. It isn't like the lines can go straight in as they have to have either 90 degree elbows and/or banjo fittings to work too. The way I have my lines set up, I don't have to un-hook anything to pull/swap turbos and the lines you do see look VERY clean IMO. Yes I use more line, but IMO, I like just feeding the heads from the front and regulating off the back.
Ok well anyways, (again IMO) once you decide to drop the OEM fuel pump and go with custom lines and what have you, the price can start racking up pretty quick on you. I have my fuel system setup pretty solid and should hold up for a good while. It has been doing great now for about a year and I have no plans to really change it anytime soon. I have a sump feeding an Airdog 150 (that's right Dale, I said airdog ) that feeds an Aeromotive A1000 that then feeds the heads and RR kit that I made and I also have the Aeromotive billet speed controller to allow the A1000 to run at low speed during low rpm and low throttle positions but as the pedal is applied, it speeds the A1000 up keep up with flow.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 12 Old 05-07-2013, 04:27 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
AD150 dont count, its the feared 175 that is the devel!!! booohahahahaha!
A/C ASW A/W WINGS
post #6 of 12 Old 05-07-2013, 05:30 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Nate, I now feed the back of the heads in my regulated return, with hard lines, not braided stainless like I had before. IMO it is a lot nicer looking, of course, i don't exactly have anywhere to run lines from the back of the motor to the front. To each his own I guess, in my case, feeding the back of the heads was a lot easier.
To the OP, how big of injectors are you planning on running? If you are planning on anything smaller than 190s, the most reliable fuel system is going to be the OEM fuel pump and a regulated return. If you want additional filtration and air removal, and AD150 or low Pressure FASS used as a lift pump to the stock pump works very well.
ccdemo71 likes this.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 12 Old 05-07-2013, 05:31 PM
just our 2 cents but we are a fass dealer for good reason.
cfd_shop is offline
post #8 of 12 Old 05-07-2013, 06:44 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Nice to know I might be calling you!!
A/C ASW A/W WINGS
post #9 of 12 Old 05-07-2013, 08:33 PM
Hey Nate what are you using for tach signal?
mikeproc is offline
post #10 of 12 Old 05-08-2013, 04:17 AM
BACKYARDIGAN
Quoted: 4 Post(s)
I tapped into the tach wire under the dash. I forget the color of the wire as it has been like a year but I believe it is a green and white wire. I can look in a day or two when I get back home (out of town right now on travel). Hope this helps.
Nate
