Sct trans firmness adjustment - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-07-2013, 04:46 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I know we can adjust shift firmness,is this only for WOT? My 4 to 5 ( if i have that right) shift is to soft,so I want it to shift harder.Its fine on WOT,just to soft of a shift on normal driving.I am just trying to make it to winter then I will be getting a performance trans.The other gear shifts are fine. Thanks for any info.
Robert
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 17 Old 05-07-2013, 07:21 AM
rogerallen33's Avatar
I have noticed the same thing with mine I think 3 to 4 is to soft and 5 just drops in fine with me, I can't give you any info on it, I can just relate to what your talking about, I have seen the options on my sct, but I have been to afaid to mess with those settings I don't wanna tear my trans up,, my motor in my truck has been rebuilt, don't wanna have to get a tranny rebuilt, I will stay tuned to this thread to see what someone else has to say,
rogerallen33 is offline
post #3 of 17 Old 05-07-2013, 08:04 AM
strokin6L's Avatar
Quoted: 3 Post(s)
its the 3-5 shift. The trans doesn't use 4th gear. You can tell your tuner to adjust the firmness of the shift and they will do it in the program. I just had Eric at Innovative Diesel firm up my 3-5 shift...and it made an improvement. You can also get a modded DD solenoid that controls the 3-5. I did the modded DD solenoid and also had firmed up with tuning.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 17 Old 05-07-2013, 08:06 AM
sprksonu's Avatar
i bumped up the 3-5 shift 15% and it helped out a lot
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 17 Old 05-07-2013, 08:11 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I've bump all my shifts on mine all the way to 25%...but it doesn't ever make a difference for me..it's the same at 0% as it is at 25%... but I still do it everytime I download a tune.
post #6 of 17 Old 05-07-2013, 08:56 AM
ZMANN's Avatar
Quoted: 1354 Post(s)
I always fine tune shifting
I say keep notes and when u find what u like tape the parameters to the back of the device for future reference
We Miss you Ronnie
ZMANN is offline
post #7 of 17 Old 05-07-2013, 12:24 PM
really the trans doesn't use 4th gear,, when I was running stock I swear I counted 5 gears,, does it use 4th stock? and not use 4th gear when it's tuned, if you could give me more info on this I would appreciate it
post #8 of 17 Old 05-07-2013, 12:25 PM
think im going to bump up my 3-5 to 15% and see if that helps, thanks guys
post #9 of 17 Old 05-07-2013, 03:44 PM
ok I bumped my 3-5 up to 15% it still seems a bit soft to me,,, it's better though, it seems like it made a difference in down shifting,, a big difference, I also turned my idle up to 775, I like the way it sounds when it's at idle, that also seems to make for quicker take offs, just did a test drive, I might bump the pressure 3-5 up to 25 tomorrow
post #10 of 17 Old 05-07-2013, 08:11 PM
strokin6L's Avatar
Quoted: 3 Post(s)
It'll only use 4th when trans fluid is at a certain temp...which is when its cold. When the trans warms up to a certain temp it stops using 4th gear. That's why there is no option to raise the shift pressure for a 3-4....simply because its not using it. That's why its for the 3-5
