can someone help me select a turbo - Ford Powerstroke Diesel Forum
post #1 of 49 Old 05-04-2013, 11:36 PM Thread Starter
SsB
Hi I have an 06 f350 turbo diesel with and airdog 2 and a superchips tune so really nothing done yet. I'm looking at Stage Two Sinister Diesel Powermax comes with a Batmowheel by Bullseye Performance or the powermax ssx both are just over 2000$ or should I be looking at something else. and also how are warren injectors I'm thinking of 190/100 to 225/150. (help please and thanks)
SsB is offline
post #2 of 49 Old 05-05-2013, 12:23 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
if your gonna go with that huge of a injector your probably better off going with a stage#3 mad turbo from mad turbowerks. the powermax is not gonna cut it. 190/100s have had great results with the stage 3 turbo from mtw. your also gonna need a regulated return system and a sct tuner with custom tunes, and you will need a transmission thats gonna be able to manage 600 HP and head studs and a metal cold side pipe lol the list may go on forever.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 49 Old 05-05-2013, 01:34 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yeah man, you need to sit back with a cold one, well make that a case of cold ones and do some serious reading.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 49 Old 05-05-2013, 03:22 AM
5fifty's Avatar
Thumbs up
X2
Get your credit cards, check book, money tree or all three warmed up and ready cause they r going to take a beating... LoL
Welcome to the ORG......
BTW .. Warren Diesel will take care of you!
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #5 of 49 Old 05-05-2013, 09:49 AM Thread Starter
SsB
Hi is their a website that explains all this power levels, stages and what is required to achieve them? I would like to get 500 rwhp or close to that. I got a set of ARP head studs (not Custom Age 625+), ARP Rod Bolt Kit and Victor Reinz Ford 6.0L Head Set just need to install. Would the stage 3 be to much for the head studs. I was also thinking of going with Banks power intake, intercooler, 4in turbo back, and Banks Power Six-Gun Diesel Tuner w/ iQ-Dashboard PC. But is the Edge Products Powerstroke Juice w/ Attitude CS/CTS more tunable.
(Other parts I'm might add but I need to learn more before buying Sinister Diesel 6.0L Powerstroke Headers,PPE High Flow Up-Pipes for 2003-07 6.0 Powerstroke, Sinister Diesel 6.0L Powerstroke Regulated Fuel Return Kit or should I put that money into the turbo and injectors.
SsB is offline
post #6 of 49 Old 05-05-2013, 10:23 AM
ODAWG714's Avatar
Quoted: 6 Post(s)
Get the head studs installed
Get a sct tuner with custom tunes so your trans doesn't gernade
Get a regulated return
And see how the power is. If you need more get 175/75 warren injectors and a hybrid turbo and you will be where you wanna be
Oliver
ODAWG714 is offline
post #7 of 49 Old 05-05-2013, 10:26 AM
Quoted: 2 Post(s)
Ditch the victor reinz head gaskets and get oem ford!
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #8 of 49 Old 05-05-2013, 10:28 AM
JGman141's Avatar
Ok i dont know where to start here, stay away from banks and edge for tuning. Sct is the route that you want to got with becasue it tunes your trans and ecu. I run the mad stage 4 just fine with arps and oem gaskets. You can make 500hp with tuning, exhaust, 175s, and a hybrid.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #9 of 49 Old 05-05-2013, 10:37 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
VR makes ford oem
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #10 of 49 Old 05-05-2013, 01:06 PM Thread Starter
SsB
Originally Posted by JUGERNAUT View Post
VR makes ford oem
Hi I got vr black diamond head gaskets. They are a 5 layer stainless steel gasket that looks like a oem one just black instead of blue are they similar or I should get oem?
SsB is offline
