DIY Y pipe bellows - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-04-2013, 05:02 PM Thread Starter
snafu!'s Avatar
DIY Y pipe bellows
I'm getting ready to upgrade to a MTW hybrid, 175/75s and a regulated return. While I'm in there I want to upgrade to SS exhaust bellows, has anyone cut their Y pipe apart and welded in bellows themselves? I am wondering if you need a jig to do this or can you weld in the bellows just using measurements?
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #2 of 13 Old 05-04-2013, 05:57 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
The two sets that I did, I did with markings/measurements, but I wouldn't recommend doing this without a jig. I think without a jig or mock-up motor, you'll just end up wasting your time and the V-band flange won't line up.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 13 Old 05-04-2013, 06:19 PM
kdogg85's Avatar
I done mine cab on. Cut out the old ones, then bolted the pipes and flanges down then made small cuts for a butt joint connection for the bellows. Then tacked them in, removed y pipe assembly and tig welded it together. Took about 8 hours with all the trimming, but worked out great.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #4 of 13 Old 05-04-2013, 07:00 PM Thread Starter
snafu!'s Avatar
How did they turn out, any problems with the flange not lining up with the turbo?
I may try a combination of both methods, pull the Y pipe measure everything up, cut the old bellows out, slip the new ones on and bolt back up with the new bellows in place then tack them pull the Y pipe again and finish welding.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
post #5 of 13 Old 05-05-2013, 06:06 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I would be more inclined to make a jig. Tack both ends of the pipe to a fixture and cut the flex out.
I've thought about doing this but it seems like a pain, if it happened to my truck I'd just buy a new pipe
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #6 of 13 Old 05-05-2013, 06:13 AM
bondajb's Avatar
where can one buy the bellows??
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #7 of 13 Old 05-05-2013, 08:22 AM
kdogg85's Avatar
I got them from summit. My wife's truck has them as well, haven't let go yet.
David
kdogg85 is offline
post #8 of 13 Old 05-05-2013, 10:10 AM Thread Starter
snafu!'s Avatar
I would send the Y pipe to unlimited strokers but the shipping from Alaska and back would be more than what they charge and I would also like to do the mad mod while it is out.
Does anyone know what grade stainless the Y pipe is, I only have a mig.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
post #9 of 13 Old 05-05-2013, 10:21 AM
BACKYARDIGAN
Quoted: 4 Post(s)
The OEM y-pipe is 409 stainless steel.
Nate
post #10 of 13 Old 05-05-2013, 03:42 PM Thread Starter
snafu!'s Avatar
Thanks, I'll have to pick up some 309 wire.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
