best temp levels? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-24-2008, 09:18 AM Thread Starter
bunch85e's Avatar
best temp levels?
ive got a xcal 3 comeing and a quadzilla commander. whats the best temps to run on daily driveing style for egts trans. also whats the hottest temps i can run with hotter tunes without harming anything like my stock head studs?
2006 F-250 extd cab short bed 6.0 POWERSTROKE
xcal 3/quadzilla commander with innovative tuned by eric and dj's looney tune
4inch straight piped with 5inch tip
afe stage 2 intake system
LOOKS-----
Diamo Karet 117 machined black 18x10 rims 33/12.50/18 toyo M/T's.
15% window tint all around with 5% eyebrow
Recon Smoked led lights all around with harley headlights.
how about them smokeing powerstrokes!
bunch85e is offline
post #2 of 2 Old 02-25-2008, 04:29 AM
EGT's
Long periods I would not go much above 12-1250.
Short bursts dont worry to much about, wont have time to heat soak.
Either way let the EGT's cool off prior to turning the truck off.
I have stock studs in my truck and tow a lot with it.
I think most of the puking in these trucks are caused from the Oil Cooler Clogged or the EGR cooler boiling the coolant.
If you keep the coolant below the min. line while the truck is hot, keep the coolant clean, and can beat on the truck a little without it puking then I doubt you will have a problem.
Troy Simmons
08 F450 4x4
tbsimmons is offline
