Help with SCT tuner - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-03-2013, 11:14 AM Thread Starter
Bderick67's Avatar
Help with older Xcalibrator SCT tuner
So I have an older Xcalibrator SCT tuner that came with my truck. Has basic directions of how to change tunes. Put it in the "street" mode and it definetly adds pep. Could use a little more explination on the difference between "tow" and "towbrake" modes. Also any other info would be gladly accepted.
Thanks
ID:	106161   Click image for larger version
ID:	106169   Click image for larger version
ID:	106177   Click image for larger version
Brian
early 2004 F250 CC SB Lariat FX4
* with BPD Oil Cooler/cold weather pack * BPD EGR Cooler * Scangauge II * Blue spring update * Blue wire fan mod *
* Rotella T6 w/ Archoil 9100 * 4" catback exhaust w/5" tip
* 63,5xx miles *
Bderick67 is offline
post #2 of 6 Old 05-03-2013, 12:01 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Brian, I would imagine that the tow tune is just that and the tow brake tune is a tow tune with a jake brake added. On my tow tune that I got from MPT I use the tow/haul button to activate the jake brake which uses the turbo to slow the truck/engine down. It really works! Yours might be on without having to use the tow/haul button. You could always call SCT they would have a definite answer.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
post #3 of 6 Old 05-03-2013, 04:44 PM Thread Starter
Bderick67's Avatar
Thanks, kinda what I was figuring. I wonder if i can get rid of one of the tow tunes and replace with another tune.
Brian
* 63,5xx miles *
post #4 of 6 Old 05-03-2013, 05:29 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Best advice I can give you is get rid of it and get a newer device that allows you to add custom tunes.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #5 of 6 Old 05-04-2013, 06:03 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I agree I don't think that SCT even supports that anymore. The tunes in that version I believe are per-programmed and cannot be changed by the end user.
Shawn
post #6 of 6 Old 05-04-2013, 06:38 AM Thread Starter
Bderick67's Avatar
Yeah proboably just stick with it for now. We'll find out in a couple weeks which of the two tow tunes work the best. Don't use the street mode much as it brings down the fuel milage. I was just lookin to maybe get a tune to boost fuel economy.
Thanks all.
Brian
* 63,5xx miles *
