turbo back exhaust... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-02-2013, 02:10 PM Thread Starter
valentic07's Avatar
has anyone heat wrapped the down pipe when installing an aftermarket exhaust? im going to be buying the MBRP 4" turbo back "off road" exhaust and noticed the stock exhaust has heat shield wrap on the down pipe off the turbo, just wondering if you guys have put it back on or used some sort of wrap.... thanks
valentic07 is offline
post #2 of 9 Old 05-02-2013, 02:18 PM
Quoted: 2 Post(s)
I didn't when I did mine, I have shielding on the motor and firewall. And be careful with that stuff, it's full of fiberglass. NOT FUN if you are under it.
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 9 Old 05-02-2013, 02:45 PM
Only thing wrapped under my hood is the up-pipes(ceramic coated and wrapped)
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 9 Old 05-02-2013, 02:56 PM
Quoted: 2 Post(s)
Like this?
Troy K.
SCT X4
XDP coolant filter
Blue Spring
Leveled
5100's
Turk.919 is offline
post #5 of 9 Old 05-02-2013, 03:26 PM
Yeah sometimes you really have to think about wrapping your tube.
Hulkamania is offline
post #6 of 9 Old 05-02-2013, 04:07 PM Thread Starter
valentic07's Avatar
yeah just like the pic, i just dont want excessive heat on the motor. im thinking about using header wrap til it bends towards the back. I work in HVAC so i know ALL about fiberglass, and it sucks big time
post #7 of 9 Old 05-02-2013, 04:11 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
Is the down pipe mild steel or stainless? I've seen wrapped steel headers rot within a year when driven daily including wet weather.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #8 of 9 Old 05-02-2013, 04:20 PM Thread Starter
valentic07's Avatar
i have no idea, its aluminized steel from MBRP part number S6212PLM
post #9 of 9 Old 05-02-2013, 05:36 PM
You dont have to wrap the downpipe.. No worries. I have a 4" dp not wrapped.. Only thing wrapped on mine is the wrapped up-pipes- this is where the most heat will be created i would think
bpd
Warren comp trans
04cr450 is offline
