Best single place to buy the best fast and tow tune - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-01-2013, 07:50 AM Thread Starter
I have researched the forums for 6.0 tunes and I have yet to find one place to get 2 possibly 3 tunes from that everyone likes. Tow tune may be what makes my decision on where. It seems like there are lots with good performance tunes but you don't hear a lot of reviews on towing unless everyone is using the race/street tunes.
I have a 2003 f250 6.0 4x4, 285 tires, studed, egr delete, no cat or muffler, pull a 10K trailer occasionally on weekends little to no hills. Live in Michigan so I don't want cold start issues. This truck is not driven daily but when its used 50% for towing.
I want one a tune for daily driving with lots of power, but I still want to it to be drivable everyday. No cold start problems.
I want a tune for towing 10K that shifts good and has good power still I hold the peddle to the floor when towing, but rather want something that I can use to get up to 60-65 fast and be able to pass on two lane roads. I would like to hear what others think of a tune with a jake for towing. Does it just work with the tow/haul button on?
johnsdeere999@yahoo.com is offline
post #2 of 6 Old 05-01-2013, 10:28 AM
jaysshortbus's Avatar
I run matts srl and love it and have heard his tow tune is good also but have never tried it !!
Jay
jaysshortbus is offline
post #3 of 6 Old 05-01-2013, 10:39 AM
sprksonu's Avatar
i have the SRL tune from Matt at Gearhead, very nice power through the curve low smoke, low egt's and shifts spot on. As for his tow tune its great for studded trucks you can tow 13k with his performance tow and he also has a trans only tow tune which is unlimited weight. their customer service is great and very knowledgeable and fast service and will adjust tunes for anything that you dont like about it. you can get all 3 tunes for 100$ which is a steal here is the link for their webpage Gearhead Automotive Performance
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #4 of 6 Old 05-01-2013, 02:46 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
There is no such thing as best tune, different trucks with different PCM strategies and mods will react slightly different, not to mention different personal driving habits.
I've got race and tow tunes from Gearhead, Innovative, Quicktricks and older tunes from DJ's (Vivian's). I like all my race and tow tunes, but each one has its own characteristics.
This is where custom tunes come in, you can get a tune, test it out and if there is something you don't like, have the tune writer adjust to your liking.
Some prefer early TC lock up, some prefer late TC lock up. Early fuel, late fuel. Higher or lower shift points. Higher or lower trans shift line pressure. VGT open or closed at idle. Light switch effect or progressive. Jake brake or none. Might be some I missed.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 6 Old 05-01-2013, 05:16 PM
5fifty's Avatar
I am running tunes from Matt @ Gearhead Automotive. I don't have any experience with other companies but I can say that I am pleased with the ones that I got from them. I've got a light tow and a heavy tow and both are nice. They have great customer service btw!
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #6 of 6 Old 05-01-2013, 05:43 PM
Snake's Avatar
Quoted: 46 Post(s)
unobtainiumdiesel.com is THE only place to go
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
