SCT Update - Ford Powerstroke Diesel Forum
post #1 of 23 Old 05-01-2013, 04:53 AM Thread Starter
Oilylizard's Avatar
SCT Update
Updated my X3 lastnight and it now holds 10 tunes! I guess I need to buy some more tunes and fill some spots!
2005 F-250 4X4
Harley Davidson Edition #00902
Leveled, Sinister Egr Delete, Studded, Sinister Coolant Filter, Rotella EC1 Coolant, 58v FICM, 6.4 Banjos, Blue Spring, SCT Tuned by Innovative, TSD
and the Wildman, Edge CTS W/ EGT Probe, 4" Turbo back straight pipe, CCV mod, 08 Tails, 08 Pan and filter, 08 Rear Diff Cover, 03 whistler
Oilylizard is offline
post #2 of 23 Old 05-01-2013, 05:20 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Damn!! It's only for the newer style X3's!! Bummer for me.
Thanks for the info.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 23 Old 05-01-2013, 05:29 AM Thread Starter
Oilylizard's Avatar
Bummer man
2005 F-250 4X4
post #4 of 23 Old 05-01-2013, 06:22 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1682 Post(s)
Did you try to load more than 3 tunes. I updated mine and it showed 10 spots but only the top 3 could be loaded.
Sent from AutoGuide.com App
toren302 is offline
post #5 of 23 Old 05-01-2013, 06:24 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I asked the same question too,but was told it would only accept 3,however I didn't try to see if it would allow more.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #6 of 23 Old 05-01-2013, 07:25 AM
pcris's Avatar
Whats the newer style X3's? How do you tell?
Edit: Just remembered I have the SF3 with canned tunes
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
Blue Spring | FP Gauge
PMM Coolant Filter
Leveled|35's
LED Reverse|Bed Rails
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #7 of 23 Old 05-01-2013, 07:29 AM Thread Starter
Oilylizard's Avatar
Yes, all 5 of my tunes are loaded onto the handheld
2005 F-250 4X4
post #8 of 23 Old 05-01-2013, 07:45 AM
Send a message via Skype™ to bwmtnbiker
Mine refuses to update
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #9 of 23 Old 05-01-2013, 07:50 AM
The truck will need to be on stock tune in order to update correct?
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #10 of 23 Old 05-01-2013, 08:27 AM Thread Starter
Oilylizard's Avatar
I always go back to stock to update, and it did take me 2 trys to get it to update.
2005 F-250 4X4
