EGR Probe Location - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-29-2013, 01:59 PM Thread Starter
Dene2006's Avatar
EGR Probe Location
I just picked up my 2004 PSD from the mechanic. I got the EGR deleted and while he was at it I asked him to install a new EGR probe I got for my Edge Insight. He installed it right behind the turbo instead of the drivers side exhaust manifold like Edge states. I phoned them up and Edge said it is next to useless there and it will read up to 200-400 degrees from what the actual temp is. The mechanic argued that is where he always puts them and you get a combined reading off both sides of the motor, (makes sense). He said all big rigs are like that and it isn't near 400 degrees different. Should I push the subject and take it back? (1.5 hour drive one way).
2004 F250 CCSB 2wd
SCT = Gearhead & Looney
MBRP 4" / S&B CAI
Borrowing money is like negotiating a pay cut for your future self...
Dene2006 is offline
post #2 of 12 Old 04-29-2013, 02:16 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Probably something you should have discussed prior to dropping it off. There are a number of folks who runs theirs in that location and a number of folks who run it in the driver side manifold (like I have done). Some guys run more than one, measuring both manifolds (as I have my passenger side tapped), and others run three, measuring both manifolds and the down pipe.
Measuring the exhaust in the down pipe isn't necessarily bad, it's giving you what your output temperatures are from the back side of the turbo and turbine life can be degraded with excessive temperatures. Personally, I think it boils down to preference. I don't see an issue either way. You'll just know the temperature of the air coming off the turbine...depending on how far away the probe is located from it.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 12 Old 04-29-2013, 02:23 PM Thread Starter
Dene2006's Avatar
Thanks Shack, I needed somebody else's opinion to put my mind at ease.
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #4 of 12 Old 04-29-2013, 02:41 PM
I think there Is a significant difference in the two locations temperature wise. Most guys use the manifold, I think it's the standard location so when everyone is talking temps you'll have to know how to convert those numbers to your setup. Like when I tell you I hit 1650 on a wot run you better not do the same with the EGT probe in the downpipe, that would be cooking. Personally I would rather have it in the manifold like most other folks do. It's easy to do yourself just need a drill, bit, and the right NPT tap.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #5 of 12 Old 04-29-2013, 03:46 PM
Term3's Avatar
Quoted: 2 Post(s)
To me when you have the probe in the down-pipe your always saying to yourself "oh yah my exhaust entering my turbo is actually 200 degrees hotter" so why bother mounting it in a location where the response time is so much slower. I've seen on a truck which had probes in both exhaust manifolds and the down-pipe that when the exhaust manifold hit the "time to back off on the throttle" that the down-pipe temperature continued to climb even though the exhaust manifold was several hundred degrees cooler. Sure, a probe in the down-pipe is better then nothing but IMO not at all the best location for it.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 12 Old 04-30-2013, 01:40 AM
99powerstroke62's Avatar
Quoted: 56 Post(s)
If he put it post turbo, it's useless.
Best place is the manifold.
If he put it in the y-collector it's still useless. The mechanic said all the "Big Rigs" do this. Well they can cause there inline 6
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #7 of 12 Old 04-30-2013, 02:03 AM
PowerStrokedRedneck's Avatar
Inline 6 or V8, it doesn't matter. Pre-turbo will give more actuate cylinder temps and move around a lot faster. And post-turbo will move slower. All of your semis, V8s included run post turbo. You have to also consider what happened when that probe tip comes off. I would rather deal with the temps than buying a new turbo.
PowerStrokedRedneck is offline
post #8 of 12 Old 04-30-2013, 03:29 AM
There are reasons that race trucks may have a probe in the down pipe and/or a couple other locations, but they will also always have one where it belongs, in the exhaust manifold. You want to know what the temps are at the cylinders. Anywhere down-stream from there is useless information unless your driving a serious race truck.
WLDHRSE is offline
post #9 of 12 Old 04-30-2013, 03:34 AM
As a side note to the OP...
If your mechanic is doing stuff to your 6.0 based on nothing more than what the big rigs do, you should probably be looking for a new mechanic.
I wouldn't even take it back to him to have the probe put in the correct location. It will be easy for you to plug the current hole and drill & tap the correct location. Fix it yourself.
WLDHRSE is offline
post #10 of 12 Old 04-30-2013, 06:39 AM Thread Starter
Dene2006's Avatar
Time to buy a correct sized tap then and attempt it myself.
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
