Injectors or turbo upgrade first?? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-29-2013, 02:00 PM Thread Starter
LiftedStroker05's Avatar
im going to do a upgrade to either the injectors (probably 175s) and a turbo upgrade (MWT hybrid or s360) but i can only do one or the other first. so which one would be my best option? i was thinking injectors first but them my egts will be outta control. maybe not, idk haha. what do you all think? i have a airdog fuel system and the blue spring mod to support injectors as well
'05 f250 6.0 stroker
ARP studs, Barder fmws468, warren 225/75s,EGR delete, stage 3 hdp trans
4" MBRP to 7" tip,sinister collany system
sct tuned w/ SRL++ xtreme tune
20x12 riots with 420s
Air Dog fp150 w/ 1/2" fuel lines,blue spring mod,
zoodad mod,traction bars
LiftedStroker05 is offline
post #2 of 21 Old 04-29-2013, 02:18 PM
04cr450's Avatar
Thats a tough one because they both go hand in hand. I would just save up and do both at the same time.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 21 Old 04-29-2013, 02:24 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
First, I'd get rid of the airdog. :
Really though, I was running 175/stocks with an oem turbo and my egt's were manageable. You can also have your tuner pull fuel to help keep the egts under control. If you're dead set on doing something right away, then I'd go with injectors first but if you have have time, I'd save up and do them both at once.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 21 Old 04-29-2013, 02:24 PM
powerstrokecrzy's Avatar
Quoted: 241 Post(s)
I just did 175cc/stock injectors and hsave a stock charger with a batmowheel. Egts are fine with my full fuel tune, and smoke I can control pretty well with my foot. I'd say go injectors first, u won't regret it. I haven't towed yet but will in a couple weeks, I don't expect any problems.
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #5 of 21 Old 04-29-2013, 03:38 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
Ported intake manifold would be a better option. Improved airflow will only add to the gains from a larger turbos or injectors later down the road.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 21 Old 04-29-2013, 06:58 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
WHS^^^^^^^^
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #7 of 21 Old 04-29-2013, 07:42 PM
rdunagan's Avatar
i honestly dont see the point in going with this first. yes it helps but it can wait for sure.
op i would say injectors first and then turbo. either way it honestly doesnt matter but injectors you will feel the power, turbo you will have to wait to feel the power gain until you get injectors. you will feel a slight increase but nothing like you will with injectors
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #8 of 21 Old 04-29-2013, 07:52 PM
snopro_03's Avatar
X2 with what rdunagan said. Big injectors and a stock turbo is lots of fun from personal experience. If you need to tow use your stock file or have someone write you a tow tune if your concerned about egts.
Chad
2003 6leaker
N.E.W 2.5 Truck
snopro_03 is offline
post #9 of 21 Old 04-29-2013, 08:47 PM
injectors. many people have driven 190/100 stock turbo for a while just dont be an idiot
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #10 of 21 Old 04-29-2013, 09:02 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1662 Post(s)
I did injectors first...then bought a IIS hybrid. Sold the hybrid and went back to my stock 03 and put a billet wheel in it and I swear the 03 with the billet wheel is performing better than the bigger hybrid I was running. I would do sticks first then the bigger snail. I will say this as a warning... It will never end from here. Your going to want more and more and more........
toren302 is offline
