Threw a rod, Golf ball size hole. Build thread - Ford Powerstroke Diesel Forum
post #1 of 47 Old 04-29-2013, 10:04 AM Thread Starter
Okay, so after my turbo shaft breaking, attempting to rebuild the turbo and failed, bought a used turbo, a week later I shoot a rod through my block. Why? I'm not really sure, but I do have an injector that you could obviously tell it was going out, skipping on idle, extra thud ect act, my theory is the the injector hydrolocked that cylinder and the rod was like "F it, I'm outta here"
So now I'm left with a hole and the debate is upgrade rods?
I have read a lot about this and from what I hear the lower end of the engine is flawless, most of the time, and that not a whole lot of people change rods if it's a daily driver. What are my options for replacing my rods that's reasonable?
Also while I have my engine and truck apart I am wanting to do some things to improve it's longetivity. Knowing the 6.0 lacks in fuel, I'm wanting to put in:
-RiffRaff's Blue Fuel Spring mod w/cover for $62.81
-Innovative Diesel's FASS 95GPH fuel system for $630.80
-Ed's FICM repair that's outta a town here in Iowa (Tuning it with Atlas 40) $150
-Elite Diesel Engineering's Stage 1/1.5 DIY Injector Kit for $950
Doing those few, but costly, things SHOULD cure the 6.0. As every 6.0 owner knows you should never assume with these heffers
I am open to your opinions, advice, and other ways to go about this. I'll be updating this during and after the build.
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #2 of 47 Old 04-29-2013, 10:16 AM
JGman141's Avatar
I would have warren diesel do the injectors because they have alot of experience with them. It would cost alittle more but you know that they are done right and his customer service is awsome.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 47 Old 04-29-2013, 10:27 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
The good thing about Jesse's injectors is he doesn't plug spill ports anymore. That sucks that you put a rod through the block though. There's always the option of Carillo Rods but they have a hefty price tag along with them.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 47 Old 04-29-2013, 10:54 AM
Snake's Avatar
Quoted: 46 Post(s)
If this was a 7.3 with PMR's or a very high horsepower 6.0 build, I'd say upgrade. But the bottom end (including the rods) on these motors is pretty stout. I haven't heard if many people who have windowed a 6.0 block.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 47 Old 04-29-2013, 04:07 PM
kdogg85's Avatar
I windowed mine, it was from an over rev. I went with a 24v vs another ford.
Get the block at least honed with new bearings if it doesn't need bored. Then the usual head studs and what not. I would get it hot tanked as well. Clean all the crap out of the water jackets and oil passages.
I would pass on the fass and use a fuel lab pump with filter and separator. They are just as frowned on as the ad2. And make a regulated return system to manage pressure.
Another vote for warren injectors, had two sets from him and never had a problem.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #6 of 47 Old 04-29-2013, 04:51 PM
5fifty's Avatar
Another vote for Warren.. on the injectors.
I was actually going to swap in a Cummins but decided against it to save me a few headaches...LoL
Gooduck w your buildup!
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #7 of 47 Old 04-29-2013, 05:44 PM
rdunagan's Avatar
nah you dont need rods for what you wanna do and another vote for warren
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #8 of 47 Old 04-29-2013, 06:26 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
You may just want to contact blackwater engines or Asheville, get the long block from them
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #9 of 47 Old 04-30-2013, 07:08 AM Thread Starter
Is Warren a one man show? Or a decent company? Also where can I contact Warren and does he do the DIY injector upgrade?
What's the difference in blocks? My mechanic has a block sitting around I'm picking up for cheap so I have a work hog again
Reezy71x is offline
post #10 of 47 Old 04-30-2013, 07:15 AM
doubledrop's Avatar
Not a one man show and as far as I know doesn't do DIY.
Sent from AutoGuide.com App
__________________________________________________ ______________________________
doubledrop is offline
