Any FASS owners out there? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-28-2013, 05:42 PM Thread Starter
jwsland's Avatar
Tossed out the AirDud and bought a FASS 200gph HD series. I'm working the bugs out, here's my problem. The pump takes 15-30 seconds to prime every single time I start the truck. I'm using a sump, not the ontop of tank setup that FASS provided, FASS said a sump is ok to use.
I noticed in the moring when I start my truck my pressure is at 70psi. After driving all day when I get home it usually 55psi. This is without me making any adjustments.
Sidenote- I'm using a driven diesel regulated return.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 21 Old 04-30-2013, 04:45 PM Thread Starter
jwsland's Avatar
I'm stumped. This unit is seeming just as unreliable as an Airdog and I haven't even had it for a week.
I put a separate pressure gauge on the fass system. Sometimes its 90psi, sometimes its 50psi. So frustrated!
Two pumps, different brands now acting the same. Maybe its something else....
jwsland is offline
post #3 of 21 Old 05-01-2013, 03:52 AM
People were having problems with FASS long before Airdog. These pumps are basically of similar design and will have similar results. You may want to try feeding it with a stock 6.4 pump, that appears to have made Juggernaut's AD happy. Would probably work the same with your FASS.
WLDHRSE is offline
post #4 of 21 Old 05-01-2013, 06:20 AM
Is the stock 6.4 pump better than the stock 6.0 pump? If so instead of me buying a fass or airdog, is a 6.4 pump just as good
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #5 of 21 Old 05-01-2013, 06:45 AM
Quoted: 908 Post(s)
Feedback Score: 3 reviews
Not sure if you really want to go with a 6.4 pump as it's not a huei system. Different fuel pressure requirements I believe. Can't say for sure though. For people that own 6.0 and 7.3's have better success with OEM pumps and if you need more fuel volume they tie in two OEM pumps in parallel and install an aftermarket fuel filter like a raycor or something
Corey@CNCFAB is offline
post #6 of 21 Old 05-01-2013, 06:46 AM
strokin6L's Avatar
Quoted: 4 Post(s)
the 6.4 pump is a low pressure 8psi pump. I love my FASS....however mine is a low pressure pusher pump feeding my fuelab. i've had it for around 7 years with no problems. I first ran it feeding my stock pump.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #7 of 21 Old 05-01-2013, 07:31 AM
Eric@PTP's Avatar
You can use a 6.4 pump to feed another pump with but you can not use a 6.4 pump solely as your only lift pump. The 6.4 pump is a high volume low pressure pump, operates at 10 psi. It's no where near the psi needed for a 6.0 or 7.3 HEUI injection system. You would still need a lift pump capable or 60 psi or better. The issue with the AD or FASS on a 6.0/7.3 is they require constant high pressure which is hard on pumps.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #8 of 21 Old 05-01-2013, 07:35 AM
Is there a thread or a write up on using both pumps on the 6.0?
Reezy71x is offline
post #9 of 21 Old 05-01-2013, 07:38 AM
Eric@PTP's Avatar
That I'm not sure of that, its possible though being there are a few members on here running that set up. You can use another pump such as a low pressure Fuelab as well.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #10 of 21 Old 05-01-2013, 08:41 AM
XL trash...
Merc82's Avatar
Quoted: 334 Post(s)
6.4 lift pump and AD2 165 success!!!
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
