EGR Coolers vs EGR Deletes - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-27-2013, 09:27 PM Thread Starter
What is the difference between a egr cooler vs egr delete? What is the pros vs cons? Looking to get one just not sure which one to get. I have a 07 f350 6.0
dezert7 is offline
post #2 of 3 Old 04-27-2013, 10:57 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
The EGR system uses a cooler to cool the exhaust gasses as they come in from the up pipe before they reach the intake manifold. All stock 6.0 motors have an EGR cooler. They are known to rupture allowing coolant into the cylinders resulting in blown head gaskets. You can get an aftermarket EGR cooler like the one from Bulletproof Diesel that won't rupture on you but is not as efficient at cooling the exhaust gasses.
A better solution if you don't have emission inspections where you are is to completely delete the egr system and make it go away. That is what an egr delete does. Your motor will thank you.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 3 Old 04-27-2013, 11:48 PM
JustinOOO9's Avatar
Quoted: 474 Post(s)
Garage
agreed... basically the EGR recirculates hot gasses back in the engine to be burnt again. so there are a few pipes in the egr cooler. coolant in some and exhaust gases in others. the gases go in cooler and coolant flowing cools the gases down again... but the ford gld coolant was known for creating sludge and clogging the coolant pipes. then they ruptured under pressure and coolant/gas mix creating bad problems down road...
bulleptroofdiesel created a cooler with larger diamiter pipes so they won't clog or mostly likely won't clog comes with their lifetime warranty. but still putting extra heat in the engine. heat=death...
the delete system just doesn't alow gases to be recirculated but... causes check engine light on late build 04 and up... you need a tuner to turn it off. I just got an egr delete didn't notice anything to be honest but peace of mine was worth it for me. I was having headstuds installed with many other parts anyways.
p.s. some smog shops have no idea so your good .
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
