MTW single plane wheel for a stock turbo - Ford Powerstroke Diesel Forum
post #1 of 27 Old 04-27-2013, 12:40 PM Thread Starter
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Well my wheel arrived yesterday just in time for me to spend a few hours today swapping out my 03 turbo for my 06 turbo + the billet wheel. I've never been too intrigued by performance stuff but when I saw the single plane wheel for a stock turbo I knew I had to have one eventually.
There is definitely a difference down low, as soon as I pulled out into traffic I noticed instantly that the lag was significantly less. I put about 20 miles on it so far and I'm liking it a lot. Not sure if theres any noise difference because my ears are still ringing from the 03 turbo.
Also picked up one of these. I've got another 05 turbo that needs a rebuild so that'll be my next project.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #2 of 27 Old 04-27-2013, 01:15 PM
turbotibbo's Avatar
right on i am glad it made it safe . did you notice any drop or rise in egt? i am loving my wheel in the 03 , but there to different wheels
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 27 Old 04-27-2013, 02:46 PM Thread Starter
Powerstroke Techie
Quoted: 13 Post(s)
Garage
I don't watch EGT because I hardly tow much and the truck is basically stock
post #4 of 27 Old 04-27-2013, 06:47 PM
turbotibbo's Avatar
Ok gotcha . Do u no what the difference is between our wheels ? Is mine single plane and yours double plane ? If so what's that mean ??
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #5 of 27 Old 04-27-2013, 07:27 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Supposedly the single will move a bit more air. How much is to be determined...
MrOneEyedBoh is offline
post #6 of 27 Old 04-27-2013, 07:29 PM Thread Starter
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Notice all the blades are the same length on my wheel. A dual plane has alternating long and short blades.
The difference may not be much, I'm not sure exactly but I'd imagine a dual plane would be less restrictive and more efficient at higher speeds. The single may move more air at a lower speed but become less efficient up high.
-Matt
2015 F-250 XLT 6.7L
post #7 of 27 Old 04-28-2013, 05:34 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Matt is absolutely correct. I believe that the 03 wheel will out flow the 05-07 wheel mostly due to the fact the 03 wheel has a higher trim to it and still has 7 big blades. Neither wheel will flow as much air as say a Stage 1/Pmax billet wheel, but when talking about stock turbos, these little wheels do actually seem to give a little bump in airflow for a little more power and cooler EGTs.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 27 Old 04-28-2013, 01:46 PM
I'm going to do a boost gauge for before/after when I drop my wheel in. I'll let y'all know how it goes. Personally, if it ONLY reduces spool time, then I'll be happy. Anything after that is going to be gravy to me.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 27 Old 04-28-2013, 03:21 PM Thread Starter
Powerstroke Techie
Quoted: 13 Post(s)
Garage
The difference is there, it seems to be getting better too. I'm noticing it a lot more today pulling all the hills I normally do. Very pleased so far.
post #10 of 27 Old 04-28-2013, 05:32 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Want to come off that 03 turbo?
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
