injector, turbo, towing! - Ford Powerstroke Diesel Forum
post #1 of 75 Old 04-26-2013, 02:50 PM Thread Starter
617mach 1x's Avatar
hey guys, to make this short anyone have any experience towing with an
MTW hybrid and 175/50 or 190/50 injectors?
need to know since my injectors are leaving for machining tomorrow!
little about my setup
custom 4in intake
ported manifold
fuelab fuel system (built like TDS system)
full regulated return
ported intake manifold (egr removed)
ipr coolant filter
then the normal stuff ARPS, SCT, exhaust etc...
studded, stacked,chipped
trans, turbo, tire and injectors??
617mach 1x is offline
post #2 of 75 Old 04-26-2013, 05:57 PM
Tell us a little more about what you plan to tow. I've been towing around 6k and I'm getting by if I'm careful. But when I start towing some heavy loads this summer I think I'll be in trouble. I would say the 190's are to much for the hybrid towing or not. Mods in my sig.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #3 of 75 Old 04-26-2013, 07:04 PM
kTm520's Avatar
I tow 190/100's with a pmax and gearheads got it dialed in pretty well to tow decently. Youll be fine to tow. Only thing i dont like is my airdog. On 3rd one. Wish i had a tsd fuel setup
2005 King Ranch, arps, oem gaskets, pmax, 190's/100's bu warren, egr delete, 5 inch exhaust, sct tuned by quick tricks/innovative/gearhead, suncoast trans, custom paint work work
kTm520 is offline
post #4 of 75 Old 04-26-2013, 07:47 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I would go with the 175/30's with an MTW Hybrid. That will give you a good all around setup. 190/50's won't kill you but you are likely to have to pull fuel to keep egt's and smoke down and I personally don't like tuning that way.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 75 Old 04-26-2013, 08:13 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Okay, since we are talking about this, what would be the difference when towing with 155/30, 175/30 or 190/30? They all should run almost the same on the same tow tune essentially, no?
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #6 of 75 Old 04-26-2013, 09:21 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
If they were all built the same with different core sizing, with the same PW you couldn't tell the difference.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 75 Old 04-26-2013, 09:49 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Okay that's kinda what I thought. The PW in combination with the nozzle size dictates the power out put more than the body size, at least for the sake of a tow tune tune when you don't need full fuel.
Future Mods:
-Alex
Fox Hunt is offline
post #8 of 75 Old 04-27-2013, 02:38 AM
kTm520's Avatar
The whole purpose of custom tuning is to tune the truck to your needs. If you get a bigger injector, for the towing the pull the fuel back give you exhast brake ect.. For your specific application. Then when your not and its all play you load your full fuel srl like i have and its all play and great mpg's. You can always detune a little for towing and not when your playing. So in my opnion if your spending the money get the nastiest setup you can.
kTm520 is offline
post #9 of 75 Old 04-27-2013, 04:52 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I believe tuning is what brings everything together. I have 190/100s and just a regular MTW Stage 1 with a billet wheel on my truck and Chris's SPD tune (same tune I used with a Stage 3 to hit 605hp on Bill's dyno last year) and I believe I could easily tow 5-6k lbs here where I live in the hills of WV. Perhaps the timing is too far advanced because it is a race tune so towing heavy is probably out, but it just keeps reminding me how tuning can do A LOT for mis-matched parts.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 75 Old 04-27-2013, 05:04 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Subscribed.this is definetly of interest to me,because I am thinking 155/30s but the 175's are still in my mind.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
