Recommendations for smokeless Power - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-26-2013, 04:14 AM Thread Starter
Therabbittree's Avatar
Looking for recommendations for smokeless power. Truck is a 2005 Excursion with a 2004 sticker on engine, has ICP in pass valvecover etc. Tearing it apart for Head Gaskets now. Looking to Tow with it and make some power with out smoke. I have a little stiction issues now with stock injectors, when I use rev-x, it goes away for about 4000 miles just in time for new oil change , running the 15-40W Kendal Super D-XA synthetic blend. I have full set of guages( egt, boost, trans temp, fuel pressure, HPOP, and Scan Guage 2) and HPOP isn't weak with the stock injectors. I haven't tried the shut icp, air pressure test yet.
I was looking at getting soem warren 155/stock or 175 /stock injectors...maybe /30's. Again i don't want to be blowing smoke. I am used to diesels, I run a built tdi and have several cummins, ve, p pump, vp44, and soem detriots.. I don't want a smokey pig as the Family cruiser lol.
I have a build thread going over inthe 6.0L excursion section, I just started the tear down etc. How much power can I get with out smokeing bad, I don't mind a little haze but no big time smoke. I remember reading about a Jefferson State Diesel 6.0L that was running 500 plus hp smoke free, it was in either Diesel Power or Diesel World Magazine etc... I'd like a 400 plus hp with no smoke and great tow capability.
Thanks,
Deo
Therabbittree is offline
post #2 of 10 Old 04-26-2013, 04:17 AM
mdub707's Avatar
If all you're doing is towing and NOT looking for smoke, stick with stock injectors. Just go with some custom tuning, it really wakes them up.
Everyone's definition of "smoke free" is different from what I've found. On my stock injectored truck my most power/least amount of smoke is a Quicktricks street tune. Fun tune to drive, basically smoke free. The only time I can even get any little tiny amount of black is coasting down the road and just go WOT instantly, it's a tiny puff and cleans up almost instantly. It's so minute that once winter rolls around I actually can't get it to smoke at all like that. Completely smoke free.
If you don't mind a little puff of smoke before the turbo lights, you can still run some hot tunes, but I'd stick with stock injectors.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #3 of 10 Old 04-26-2013, 04:58 AM
mazsecond's Avatar
Feedback Score: 4 reviews
I agree about the injectors. Theirs really no need for anything over stock if your just towing. You would be amazed what a good tune can do, it really wakes these trucks up. With stock injectors you will defiantly be able to make 400hp and nearly smoke free, if you decide do do some larger injectors your going to want a turbo to clean them up, heck the stock turbo can't even clean up the stock injectors. Their are guys on here with stock sticks and the MAD Hybrid turbo that push 500rwhp with very little to no smoke. Just do your research and a lot of reading. Right now I would just worry about making sure you get a good set of heads and get em torqued down properly. Once you have a solid foundation then the fun begins.
Sent from AutoGuide.com App
mazsecond is offline
post #4 of 10 Old 04-26-2013, 07:03 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I'm going to break with the guys above and say an MTW Stage1 with a billet wheel and 155 stock nozzles would be a great tow setup that was fun when you aren't towing. Add water/meth injection and you should have your 500 hp and with the meth injection never have a high Egt while towing.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 10 Old 04-26-2013, 07:24 AM
155 are waste of time. 175/stock and mtw stage 1. is fun setup ask me how i know.
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #6 of 10 Old 04-26-2013, 07:56 AM
Snake's Avatar
Quoted: 46 Post(s)
155's are definitely not a waste of time.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 10 Old 04-26-2013, 08:27 AM
PGreenSVT's Avatar
Not for his goals they aren't. Glad you are enjoying your combo. That doesn't necessarily make it right for everyone. You gave your opinion, don't try to invalidate mine.
RIP Mitch
the Org crew
post #8 of 10 Old 04-26-2013, 08:33 AM
Snake's Avatar
Quoted: 46 Post(s)
I also think that either stock injectors or 155's would be great for his goals.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #9 of 10 Old 04-26-2013, 11:56 AM
mdub707's Avatar
Just noticed the OP isn't terribly far from me either... You're only a couple hours away from me it looks like. If you're ever out towards Utica let me know, I'll take you for a ride so you can see what a stock injectored truck can do.
2006 F-250 6.0 4x4
VEGISTROKED
mdub707 is offline
post #10 of 10 Old 04-26-2013, 04:46 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
How about this...
Stock injectors with tuning and a stage 1 turbo = Big grin, no smoke and tows nice, normal to low EGTs.
155-175s with 30%nozzles, tune and stage 1 or hybrid, = Bigger grin, no smoke unless beating it and tows nice. The next 50-80hp requires twice the price for modest gains. Normal EGTs if tuned correctly. Maybe a stage 2.
You could go larger, but this requires a bit of dialing in (defuelling) for larger tows. 190s with 50% nozzles, tune and hybrid or stage 2-3 = Much bigger grin, no smoke unless beating it and tows fine on a specific tow tune. The turbo choice really jacks up the price. Add fuel system and exhaust as well.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
