tune temps and smoke - Ford Powerstroke Diesel Forum
post #1 of 35 Old 04-25-2013, 07:38 PM Thread Starter
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
so i just got myself an SCT Livewire TS with IDPs custom tunes.. its all in my signature.. i was wondering should i be blowing out a bit of black smoke when i'm really giving her some on the throttle? and what are your guy's average temps running the aggressive street tune.. my deltas are good the temps just seem steep over 200* for me.. maybe exhaust is in order? and anyone got a guess on these tunes for Crank HP/TQ?
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #2 of 35 Old 04-25-2013, 07:50 PM
Street Dentist
stratotrev's Avatar
I got my SCT a couple weeks ago and I seem to be blowing more black smoke than previously when I lay into her some. I assume it's normal with the tune, though I'm also new to it. My temps seem to be running ok though. I'm sure someone here has some some more long term experience with it, just thought I chime in with my limited experience since loading my tune.
'06 F250 CCLB Lariat 4x4, 6.0, Stock Height, Destination A/T 285's, 4" MBRP Turbo Back, PMM Coolant Filter, EGR delete, Bilstein's, Scanguage II, SCT
stratotrev is offline
post #3 of 35 Old 04-25-2013, 08:52 PM
kdogg85's Avatar
It will smoke due to more fuel coming in than the turbo can handle. Cruising, the ect should be what it was on the stock tune, but going up hill, it should run a little hotter due to more fuel per the same throttle input. More fuel=more heat.
Nothing to worry about.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #4 of 35 Old 04-25-2013, 08:56 PM
Adamv7010's Avatar
Throw on a set of 205/150s then ask about smoke Lol
You're good Buddy. Normal effect. Some tunes are smokier than others
Adamv7010 is offline
post #5 of 35 Old 04-26-2013, 08:30 AM Thread Starter
thanks guys! and when should i start to worry about temps? above 210? cause when i'm getting into her i float around 210-215 for EOT and 205-210 for ECT my delta is within 5-7 which is great!
mods:
Banks Ram air
EGR Delete
Other rides:
Mods:
JLT True CAI
Smoked Heads/tails
post #6 of 35 Old 04-26-2013, 08:52 AM
legionxxii's Avatar
What is your outside temp and do you have AC running? AC will bring the temps ups when running turn it off and watch the temps drop. Well thats what it did in my 03
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #7 of 35 Old 04-26-2013, 09:01 AM
DoubleDpsd's Avatar
I just loaded my spd yesterday and my temps went up also. About a 10mile drive from the valley up to my condo and my temps with atlas 40 only were ect 193 & eot 200 but now with the tune the ect was at 203 and eot at 210.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #8 of 35 Old 04-26-2013, 01:51 PM
Adamv7010's Avatar
I wouldn't worry until I got to around 215 ish ...buy conditions play a large large factor...loaded vs unloaded...flat ground vs mountains.. ambient temps...
post #9 of 35 Old 04-26-2013, 03:21 PM Thread Starter
no A/C and just a wood pallet in the bed and all my tools in the cab
outside temp is 65-72* and lots of hills.. and i was romping it when i hit 213*
mods:
Banks Ram air
EGR Delete
Other rides:
Mods:
JLT True CAI
Smoked Heads/tails
post #10 of 35 Old 04-26-2013, 04:10 PM
Yes, and IDP tunes are some of the smokiest.
Those temps sound normal and good. Mine stays around 190/195 in the winter and 195/200 in the summer. But running up Steam Valley Mountain rt 15 in PA, about 8-1/2 miles with a pretty good grade, at 85-90 MPH, my truck will run up to about 210/215. Guys towing pull those kind of temps all the time. As long as your deltas are good, you're nowhere near temps that should make you worry. Of course if the temps don't come back down in a fairly short period of time once you get out of it, then you may want to start checking things out.
WLDHRSE is offline
