SCT Tuner,how many custom tunes? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-25-2013, 07:25 PM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
This may have been asked already, but when I downloaded the software and went to load the tunes its now showing 10 places instead of 3 to load tunes. Can we now load 10 tunes?
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 8 Old 04-25-2013, 07:34 PM
kTm520's Avatar
If they made it able to fit 10 thatd be awesome
2005 King Ranch, arps, oem gaskets, pmax, 190's/100's bu warren, egr delete, 5 inch exhaust, sct tuned by quick tricks/innovative/gearhead, suncoast trans, custom paint work work
kTm520 is offline
post #3 of 8 Old 04-25-2013, 07:38 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
what model do you have? i think the new TS can hold 10
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #4 of 8 Old 04-25-2013, 08:47 PM
04cr450's Avatar
From how I was told,( I have the 3015)... It shows 10 spots but only 3 spots are "highlighted".. Only 3 are able to be stored.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 8 Old 04-25-2013, 08:49 PM
sprksonu's Avatar
ts is the only model that holds ten
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 8 Old 04-26-2013, 07:19 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I have the 3000.I guess that's what the updated software did.
post #7 of 8 Old 04-26-2013, 07:21 AM
Gushatman's Avatar
The SF3 will hold 10 as well. Not on the programmer itself, but in the computer program.
Gushatman is offline
post #8 of 8 Old 04-26-2013, 07:27 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Ok gotcha,makes sense.Now if I can just loan them without screwing the device up,somehow last night I messed that up,had to call sct for help.i don't hook the device to my pc that often.
