How do yo lower egt - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-24-2013, 06:37 PM Thread Starter
bigbaldbob's Avatar
How do yo lower egt
What are the ways to lower egt's
Any cheap ways?
The best ways?
Is there a magic number to keep egt's under say in a drag race? (1/4 mi - 1/8 mi.
Any info is greatly appreciated, don't want to kill my rig.
2005 F350 CC, LB, SRW, Fx4 Auto, Lariat,
Gauges, Exhaust, Studs, Egr, Powermax
bigbaldbob is offline
post #2 of 9 Old 04-24-2013, 06:38 PM Thread Starter
bigbaldbob's Avatar
I can hit 15 / 16 f real quik!
post #3 of 9 Old 04-24-2013, 06:40 PM
JGman141's Avatar
Water/meth works well from what I hear. What else are you runing on your truck?
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 9 Old 04-24-2013, 07:06 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Less fuel, more air, cooler air, or water injection.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 9 Old 04-24-2013, 07:17 PM Thread Starter
bigbaldbob's Avatar
All the deletes, studs, power max, sct.
post #6 of 9 Old 04-24-2013, 07:25 PM Thread Starter
bigbaldbob's Avatar
Sct power max 4"
post #7 of 9 Old 04-24-2013, 07:28 PM
3brorce's Avatar
EGTs are just numbers LOL.
Anarchy Diesel Tuning
3brorce is offline
post #8 of 9 Old 04-24-2013, 07:29 PM
While I can't remember the numbers, my 4 inch exhaust helped. I have a billet compressor wheel on the way, that should help, too.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 9 Old 04-24-2013, 10:12 PM
turbotibbo's Avatar
i just installed the billet wheel and noticed around 150 - 200 drop . a good upgrade for the oem turbo
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
