mtw 03 turbo wheel - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-24-2013, 01:01 PM Thread Starter
turbotibbo's Avatar
mtw 03 turbo wheel
Well after a little trip around the usa my 03 mtw wheel has made it to my door . I plan on doing some before and after tests with it . I have two 03 turbos and was wondering if i should install the wheel on the one in the truck or use the turbo on my shelf ? Also i am intrested in any do it yourself mods i can do to the compressor housing ? Also is there any other members on the org who also have the 03 wheel on there 03 turbo ? Imtw 03 turbo wheel-spring-2013-112.jpg
mtw 03 turbo wheel-spring-2013-001.jpgf so feel free to share your findings with me . thanks
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #2 of 14 Old 04-24-2013, 02:16 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1619 Post(s)
I don't have the mtw wheel but have the xsboost wheel in my 03. It looks identicle to yours. I love mine. Faster spool up lower egts and higher boost. When I took it to the track it hit 42psi at first then settled to 38.
Sent from AutoGuide.com App
toren302 is offline
post #3 of 14 Old 04-24-2013, 04:50 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
That's funny. I have pics of that same wheel
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 14 Old 04-24-2013, 05:45 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Did you get the single plane wheel yet Matt??
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 14 Old 04-24-2013, 05:51 PM Thread Starter
turbotibbo's Avatar
i was worried you were gonna change your mind and keep the 03 wheel . your wheel should be there in 3 days or so .
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #6 of 14 Old 04-24-2013, 10:32 PM Thread Starter
turbotibbo's Avatar
i installed the wheel and it took about 2 hrs start to finsh . i started it up and it seemed to be sucking more air . the intake noise was louder . when she was warmed up i went to the hwy and noticed a new intake sound , at wot my egts never pasted 1200 on 3 wot runs , running matts srl++on the stock compressor i was hitting 1350-1390 . its too soon to tell if there are any power increase ill have to drive it more to see , i only took it out for a quick test drive and i ran it hard , the highest boost number i seen was 28 psi at one point crusing at stock i seen 30 ans 32 on looney . 28 seems to be the normal for my truck with the srl++ . i will run it for a while and see how it performs . so far i am very happy mtw 03 turbo wheel-wheel-003.jpg
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #7 of 14 Old 04-25-2013, 07:54 PM Thread Starter
turbotibbo's Avatar
took it out today for a run and i like the new wheel , my egts are at least 50-150 lower all around. and 150-200 lower on wot runs . there is a little power increase from what i can tell . it seems like it sucks more air even when i put my hand next to the air filter i feel it sucking like a vac . also seems less laggy but more time will tell
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #8 of 14 Old 04-25-2013, 08:11 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i bet it will take close to 300-500 miles to really run like it should
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #9 of 14 Old 04-25-2013, 08:27 PM
Bump To Pass!!
toren302's Avatar
This is dead on...mine seemed to get better and better as the truck got used to it.
toren302 is offline
post #10 of 14 Old 04-25-2013, 08:30 PM Thread Starter
turbotibbo's Avatar
good to know . toren is your wheel the same as the one i have ?
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
