oil where it shouldent be - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-23-2013, 04:54 PM Thread Starter
i have what ive been told is blowby and apparently its bad. i have oil coming up through my dipstick and getting all over everything close by and even the under side of the hood. what do you guys think? gonna run the "ids" and a manuel compression check on it tomorrow and go from there. i just did a complete rebuild this is the last thing i need right now!
jherbie28 is offline
post #2 of 9 Old 04-23-2013, 05:37 PM
subscribed
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #3 of 9 Old 04-23-2013, 05:43 PM
Slacker
Evil Eye's Avatar
Quoted: 224 Post(s)
Feedback Score: 4 reviews
Do you have the CCV rerouted by chance?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 9 Old 04-23-2013, 06:02 PM
sprksonu's Avatar
x2 same question similar problem happened to another member on here ccv was kinked or blocked and was leaking oil through the dipstick tube and various other places
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 9 Old 04-23-2013, 07:07 PM
rdunagan's Avatar
if not OUCH!!!!!
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #6 of 9 Old 04-24-2013, 02:48 AM Thread Starter
i do and from what i can tell its not blocked or kinked. what cha thinking?
post #7 of 9 Old 04-24-2013, 02:58 AM Thread Starter
after a better look it looks like it could be kinked at the top where the hose turns down.
post #8 of 9 Old 04-24-2013, 11:47 AM
Slacker
Evil Eye's Avatar
Quoted: 224 Post(s)
a kinked or blocked hose is what I was thinking and it sounds like you may have found the problem.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #9 of 9 Old 04-25-2013, 02:50 AM Thread Starter
i hope so. after running fords "IDS" it checks out fine. no codes. the #4 cylinder has a 2% drop(relative compression) i still need to do a manuel compression check to b sure. i dont watch the ccv mod that often being that its under the truck but i have been more in the past 2 days. its has a pretty good flow of steam coming out of it. i had a guy tell me my trucks on fire..........
