2006 6.0 psd straight pipe? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-23-2013, 09:11 AM Thread Starter
Czlivingston's Avatar
Hey guys, I'm new here and I've been looking at straight piping my 06. I've been looking at the 4" MBRP PLM series 6212PLM (turbo back) and I was curious if thats a true turbo back or if its a down pipe back because i've read both. (I know i should probably look through the forums but i don't really have the time as I'm on deployment to Afghanistan.) Thanks in advance!
Czlivingston is offline
post #2 of 4 Old 04-23-2013, 09:47 AM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
This one? Link
That is a full turbo back system.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 4 Old 04-23-2013, 10:52 AM
Blue Goose's Avatar
First and foremost....Thank You for your service! Now, for the exhaust, I installed a cat and muffler delete pipe so that I have a 3.5" oem straight pipe. She growls when you get on it but is quiet the rest of the time. A friend of mine drove it last week and he has had a 4 and 5" system on his truck and he said he wouldnt have believed my truck was that quiet in the cab without driving it and his has a drone to it but mine does not. IMO its a cheap way to let it breathe and talk at the same time. I also tow 15-19K regularly or as needed and have had no issues with high egts. And thanks again!!
06 KR 250
Blue Goose is offline
post #4 of 4 Old 04-23-2013, 10:55 AM
turbotibbo's Avatar
Originally Posted by Blue Goose View Post
First and foremost....Thank You for your service! Now, for the exhaust, I installed a cat and muffler delete pipe so that I have a 3.5" oem straight pipe. She growls when you get on it but is quiet the rest of the time. A friend of mine drove it last week and he has had a 4 and 5" system on his truck and he said he wouldnt have believed my truck was that quiet in the cab without driving it and his has a drone to it but mine does not. IMO its a cheap way to let it breathe and talk at the same time. And thanks again!!
thios is what i did too , its cheap and works great . it cost me about 100 bucks at the local muff shop . the good thing is its only loud when you want it to be .
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
Tags
6.0 , mbrp , straight pipe
