question about lpop - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-22-2013, 12:06 PM Thread Starter
question about lpop
I have a late 04 I just done the lpop and front cover my new lpop has a wear sleve that come with it.my old lpop didn't have that sleve in it.does anyone kno do I need to put this sleve on and if so how close to the gears does it go thanks for the advice guys
dj.oneil is offline
post #2 of 14 Old 04-22-2013, 12:13 PM
licenced2burn's Avatar
Is it a sleeve for the front cover seal to ride on?
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #3 of 14 Old 04-22-2013, 12:19 PM
Like a boss!
Laferty's Avatar
Sub'd.. I havnt gotten this far into my build yet so maybe we can figure it out ahead of time. I believe I know what seal you are talking about... can you put up a few pictures?
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #4 of 14 Old 04-22-2013, 01:32 PM Thread Starter
I don't know for sure all that I can figure out is that people is cutting it off with a hack saw I and I am sure it's the same one.I just have no idea how mine has disappeared and where the new one goes
dj.oneil is offline
post #5 of 14 Old 04-22-2013, 01:36 PM
If should on the crank after the gears so that seal that's on the cover for the gears rides on it if I remember right
Tony
post #6 of 14 Old 04-23-2013, 06:53 AM Thread Starter
laferty I will put some pictures up as soon as I get home I drive truck so I am only able to work on it on the weekends. and for a few tips on the lpop when u get ready to put your front cover on if you are replacing that just make sure your manifold bolts are loose and set the cover up there start 2 or 3 bolts hand tight then take a bar and put between the cover and oil pan and pry up on it till your oil gears slide in. it work pretty well I fought with mine for a day and a half before I got them in
dj.oneil is offline
post #7 of 14 Old 04-23-2013, 07:30 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
THAT sleeve is supposed to be in the front oil seal! when your done with the gear install you need a special tool to install the front crank seal. This tool pushes that sleeve onto the crank with the oil seal as one unit.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #8 of 14 Old 04-23-2013, 07:34 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1685 Post(s)
Absoluty correct!!! The front crank seal has been updated and includes a wear sleve. It must be installed. I bleive there is a special tool, but this is how I have done the last 3 I did.
1. Get oil gears in cover
2. Install the sleeve...I belive there is a bevelved side and a fat side could be wrong Beveled side should face out.
3. With the sleeve started on the crank shaft using a block of wood tap sleeve until flush with crank.
4. Using balancer start all 4 bolts and tighted the balancer down until seated in installed position.
5. Remove balancer and install crank seal housing and seal.
Install balancer and all other removed componets.
Basically you are using the balancer to install the sleeve the rest of the way. After the balancer is removed you will see the sleeve is now set in 1/4 to 5/16 of inch on the crankshaft.
I havent had one leak or comeback yet. Works great. Hope this helps.
toren302 is offline
post #9 of 14 Old 04-23-2013, 07:38 AM
Bump To Pass!!
toren302's Avatar
DANG IT!!! Jugernaut Treeed ME! and he is correct when the crank seal is installed you should be able to see the sleeve protruding from the front of the seal.
toren302 is offline
post #10 of 14 Old 04-23-2013, 07:52 AM
Bump To Pass!!
toren302's Avatar
With the crank seal housing removed a couple of flat screwdrivers or snapon prybars will get the sleeve moving and slighly off the crank. Then a pair of vice grips will pull it the rest of the way off. Just make sure not gouge the crank at all.
toren302 is offline
