lets talk street/race tunes - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-22-2013, 10:04 AM Thread Starter
6.0 stroke's Avatar
For starters, my truck is on 37" tires has egr delete, head studs, stock injectors, intake, exhaust, stock trans. its a vxcf9h7 strategy with an 04 ficm. has good fuel pressure.
hear is my opinions on these tunes they are me sotp feel and the best as I can describe.
Xtreme street: Has awesome power. most top end power tune I have (70 mph +), smokes a good bit, shifting on this tune is a little goofy. never has shifted good on my truck causes a bad 3/5 flare, also shifts too hard. This tune seems to have a light switch effect. cold starts are little bit rougher on this tune.
Looney wild: Tons of low end grunt, smokes like a pig. It has a little light switch effect. Holds the shifts to 4000rpm+ kind of makes it seem like it falls on its face. I feel the shifts are too soft for the power but otherwise a great tune.. Looney also has the loudest exhaust note on my truck. hard cold starts
Super Panty Dropper: smooth linear power, lowest amount of smoke. Has good power.. I would say its my slowest of my race tunes. The transmission on this tune its horrible imo. At moderate acceleration this tune holds the shifts all the way to 3800 rpm then slams in the next gear I cannot stand this because I have a heavy foot. has no light switch effect, but the trans dose? Chris and I have tried hard to make it right but cannot get it. not my favorite tune.
Super Panty Dropper early lock up: Same as above just with early lock up so its even worse.
SRL+: My favorite tune, this tune screams out of the hole. locks the converter in third gear at WOT and shifts awesome, right at 3900 rpm. SRL dose smoke a lot at wot on my truck, there is a continuous haze of black. It has absolutely has no light switch effect. Shifting is the best spot on shifting no 3/5 flare feels like a built transmission is in the truck. SRL is by far the best dd race tune I have. It dose not have the top end xtreme street or Looney have. But is nice and smooth. Only complaint I have is that it locks the truck in OD at 45 and with big 37" tires it kicks up and down at 50-60 mph sometimes. cold stars are perfect. I ran this tune at the drag strip. It did a 14.16 in the 1/4 mile.
Again this is on MY truck with the way I drive its is all seat of the pants feel. I am not bashing any tuners there all great in their own way. I just want some more opinion of how these same tune compare for you guys.
2006 F350 Lariat cc sb
ARP head studs 245ft-lb, ford head gaskets
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
coolingmist water methanol 10 gph nozzle
afe intake
intake horn
6" skyjacker 20xd hoss 37 toyo mt
stock trans
6.0 stroke is offline
post #2 of 11 Old 04-22-2013, 11:52 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Awesome feedback. Matt at Gearhead is awesome. Try leaving your truck on tow haul and re gear it to 4.30s
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 11 Old 04-23-2013, 05:20 AM
Joeshu1000's Avatar
Your truck acts exactly like mine. I've never ran the Looney Wild or Inoovative tunes, but with the regular Looney Tune my transmission loved to hold gears up to 4k under light throttle. I had the same problem with the SPD and Chris tried to fix it many, many times, but never could get it, although it wasn't for a lack of trying. I have to say that Matt' SRLXX is spot on with the shifting and runs likes a freight train.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #4 of 11 Old 04-23-2013, 05:33 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i have had matts and innovatives. i run matts SRL+ everyday its pretty good but at WOT it takes RPMS to 4100+ maybe even 4200 sometimes. this scares me as i do not want to float my valves. i hated innovatives i do agree they had lots of power but the transmission shifting was poor.
i am wanting to see some tony wildman reviews as he is the one i have been thinking on trying next.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #5 of 11 Old 04-23-2013, 08:48 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1610 Post(s)
This thread absolutly illustrates the point that every truck and driver are diffrent. My SPD is the fastest and best tune I have and I really dont like erics tunes. But this is the best part of custom tunes...keep getting diffrent truck to drive when a new tune is loaded. The best way to do it is to try sevral diffrent tunes and see which work the best for your driving style and truck. I am starting to really like the Wildman extreme I have.
toren302 is offline
post #6 of 11 Old 04-23-2013, 10:16 AM
The only tune Ive used has been SPD from Chris.. I just ordered Matts SRL+ to see how it works with my trk. My SPD is fast off the line with good low end power but seems to have no top end power.. Plus it seems I have a hard time getting my boost over 22psi unless I load the engine on a hill. No turbo leaks.. Chiris says 05s can be tricky to get the boost spot on. IDK..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #7 of 11 Old 04-23-2013, 10:39 AM
I don't believe I have ever heard that from anybody else running Matt's tunes. You might want to talk to him about the smoke. Even with a leak at the Y-pipe on the p-max right now, my SRl+ doesn't smoke hardly at all.
I love my SRL+! I haven't tried any of the others and don't plan to. I've run it with stock turbo as well as a stage 1, a hybrid, and a p-max and all have run great.
WLDHRSE is offline
post #8 of 11 Old 04-24-2013, 06:28 AM
Quoted: 7 Post(s)
hes right though it does shift to OD at 45 MPH that is very annoying -_-
07 F250-SOLD
post #9 of 11 Old 04-24-2013, 06:37 AM
I guess im weird because I like it shifting to OD at 45-50mph.. But I do alot of driving were the limit is 45mph so I cruise at 50mph in OD.. It seems to help with fuel eco.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #10 of 11 Old 04-24-2013, 06:42 AM
mdub707's Avatar
Shockingly enough, it seems from your descriptions the tunes with the most fuel (visible smoke) are the fastest... go figure LOL
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
