ficm tuning questions - Ford Powerstroke Diesel Forum
post #1 of 24 Old 04-22-2013, 03:41 AM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
well ive read about all i can read from stickies and php's website about strategy rollback and what not, but it seems the more i read the more i confuse myself anyway, if i were to get the ficm tuner from php, would it change the strategy and do the tune? or just a tune and no strategy change? also, who do ya'll recommend for tuning, php or innovative? thanks all in advance
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #2 of 24 Old 04-22-2013, 05:38 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1744 Post(s)
Feedback Score: 4 reviews
from what I understand, if you get the gryphon programmer, it can only do one of those things at a time......strategy change or FICM tune......so what seems to be the best option is guys buy the programmer, roll back their strategy, then change it to a FICM tuner and you're home free. You shouldn't need to change your strategy more than once, and it gives you the flexibility of more FICM options
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 24 Old 04-22-2013, 10:24 AM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
so how does the rollback work? what do i need? any suggestions on which brand?
6.0newb! is offline
post #4 of 24 Old 04-22-2013, 10:55 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
There is only the Gryphon tuner from PHP. Get the FICM tuner. to do the roll back you hook the tuner to your PC and connect to the Internet. Bill from PHP configures the tuner to do the roll back. You take the tuner, plug it into the OBDII port and do the roll back, the hook it back to the PC and Bill re-configures it as a FICM tuner again.
Forget about IDP FICM tunes.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 24 Old 04-22-2013, 01:24 PM
Or you can send the PCM and FICM to Bill and let him do the rollback and tune on the bench. It takes about an hour on the phone with Bill to do it in the truck and coordinating that can be tough sometimes.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #6 of 24 Old 04-22-2013, 01:39 PM
DoubleDpsd's Avatar
You dont need to rollback unless you drive around in a stock tuned truck all day. If you run custom tunes the tune writer more than likely change the strategy to a better one.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #7 of 24 Old 04-23-2013, 08:10 AM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
well see thats the thing, it is stock tuned. dont want to get any tunes until i get studs. im just looking for a little more get up and go off the line, plus it seems to give a little better fuel economy. but thanks for the above replies, exactly what i was looking for! and i cant send it off as this truck is a DD for me. why a no on innovatives ficm tunes? i already figured i would go with the php tunes, just curious why. thanks
6.0newb! is offline
post #8 of 24 Old 04-23-2013, 11:06 AM
what's your issue with ID FICM tunes?
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 24 Old 04-24-2013, 05:12 AM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
bump it up, anything on innovatives tunes?
6.0newb! is offline
post #10 of 24 Old 04-24-2013, 05:44 AM
mdub707's Avatar
Everything I have read always said to use FICM tunes from the same guys you use your regular SCT tunes from. Though, even though I use a lot of Innovative custom tunes, I am going with the PHP simply to get the gryphon.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
