Head studs going in got a few questions? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 04-21-2013, 05:03 PM Thread Starter
How much (approx) does a crew cab with seats out weigh? Cab only of course.
How high do you have to raise the cab up if you wanted to roll out the chassis? Assuming the bed was off. Thinking of making a stand for the cab next to the garage. Remove the bed and the get the cab up on the stand (s?) and hand roll, tow, push, pull the chassis into the garage.
I was planning on doing gaskets and studs on a new truck whether it needed it or not. The new truck needs... I probably need new heads too. Got fuel in coolant along with the 16psi+ degas. The fuel leak is slow, there is no smoke, no coolant loss and the degas psi rate is very slow, even with the hammer down 0-80mph. The truck drives sweet getting 18+mpg all stock. It had an egr cooler failure that caused the head problems. If it does need heads I have not yet decided the route to go. Considering the costs, risks and logistics of machining old ones or remans, I really want new castings. I am nervous to get them from clearwater, even though I am leaning towards them. I've heard the are good... mostly.
The more I learn about this truck the more I want to do the work myself. I just proved it will fit in the garage at or new house diagonal! This way I will not be in a crunch for time and if the new heads do fail I will be able to remove them myself saving twice as much coin in the end. If I have to I can order the heads and get them checked out by a machine shop prior to install. I'll feel good knowing I did the job and I am capable of getting in there efficiently if some thing else needs tending to.
This truck has no rust and all the options I wanted, so to me it is worth dumping some time and money making it what I want, instead of being forced to pay way more for something I really did not want. I'm putting a lot of other updates/upgrades in while the truck is apart. I plan on upgrading fuel system, turbo, ficm, hpop and injectors after I prove this head stud job holds up to some strong tuning and abuse.
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #2 of 26 Old 04-21-2013, 05:17 PM
Like a boss!
Laferty's Avatar
Awesome. I love headstud threads. I can't answer your weight of cab questions but I can help with heads. It seems that taking off the cab in your situation without a lift would be alot more work then just doing them with the cab on. It is not that hard at all. As for clearwater, I just purchased 2 new heads from them. They are at the machine shop being double checked for cracks, flatness and valve height before I install them. According to clearwater, they have not had any issues with the new heads, only the remans and I havnt heard a story of them not honoring a warranty. I got them for $1350 and $125 for the machine shop double check.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #3 of 26 Old 04-21-2013, 05:25 PM
5fifty's Avatar
I'd say try to do it with the cab on. It is not that bad. I just did it myself. Cab on and A/C condenser still installed (pulled half the condenser shell. The Snap On torque adapter is the ticket.
As for the Clearwater new cast heads... I ran into the problem of both of my stock heads needing to be replaced. One was warped pretty bad, the other had cracks. I got a new set from them and have about 500 miles on them. No issues yet. I know quite a few members on here that are running them hard without any issues.
I got a truck that was in ok condition but it was exactly what I was looking for minus the leather, (F-550). I knew ahead of time that I wanted to build the truck my way. I planned on doing all the work I did even before I bought my truck.
There are plenty of people that have done it and can offer up their advice. Plenty of sticky threads to help along the way, Youtube as well.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #4 of 26 Old 04-21-2013, 08:01 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Do it with the cab on unless you have the means of lifting and setting the cab. It's not hard to do in cab. See the thread link in my signature. I did mine in my driveway in cab. Not hard at all. If you have fuel in your coolant you HAVE at least one cracked injector BORE (not injector cup) and at the minimum that head needs to be replaced. If your other head checks out reuse it and buy a NEW head from FORD. Stay away from Clearwater Cylinder Heads in Clearwatee Florida. Good luck and if you need any help don't be afraid to ask for it.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 26 Old 04-21-2013, 08:06 PM
Like a boss!
Laferty's Avatar
I don't think it is fair to say to stay away from them. They are selling the same new heads as QuickTricks. So stay from them also? There are only a few threads of people having problems with heads from them. I am sure they must have a ton of 6.0 heads running the streets.
2006 CCLB
Laferty is offline
post #6 of 26 Old 04-21-2013, 08:23 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
It's your money do what you want with it. Personally after having bought one of their heads myself and it failing and now needing replaced yet again I will do what I should have the first time around and just get a new Ford head. Also Shack had his NEW castings from them fail on him in 300 miles and dump coolant into the exhaust causing him to pull the heads again after only 300 miles and rebuild his turbo plus put new heads and gaskets again on the truck. Like I said its your money spend it how you want but I will never buy CCH heads again I don't care who sells them.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 26 Old 04-22-2013, 01:02 AM Thread Starter
I may have a lift available, I also hear you guys on leaving the cab on. It just looks so easy with cab off.
I want to know my options. If the cab weighs around a thousand pounds, I'll consider raising it.
Cause I'm pretty sure I need at least one new head, i really want to do this myself, for time and options reasons. Maybe i will find something during tear down to make me just want a low mile take out motor. Right now i think i do not want to install one new (or reman) head and have the old one not cracked machined. I want two of the same right, for peace of mind when the power gets turned up! Hey Maybe they both are cracked.
I'm torn on the new castings versus ford remans. Ford remans are $3000pair, with 12mo/12k warranty on parts only. We are getting into the realm cost wise of a take out motor here. I will still pay a machine shop to verify the reman heads. I forgot to ask If they come with valve train and hardened exhaust seats?? Everything I'm seeing says get hardend valve seats. I'm not doing this job just to fix it, I got some power plans.
Clearwater wants $1400 a pair delivered with return delivery for their "new" beefier castings. Their warranty claims 5years unlimited miles they come "ready to install" with valve train and hardened seats. I have heard good and bad about clearwater. my questions are What has failed on the new cch heads, were they (could they have been) checked for these issues prior to install, how did the warranty claims go? They are telling me the have not seen a new casting crack, as of a week ago.
The few problems with cch I've heard about are mainly when something
does go wrong they are not kissing booty to make it right. That's a big problem with me. When I see shyster used in negative feed back I get concerned.
Are those my only reasonable options here for heads????
Thanks for the responses, all!
Important stuff:
frashdog is offline
post #8 of 26 Old 04-22-2013, 01:44 AM
Like a boss!
Laferty's Avatar
Heads come with valves and springs. Not valvetrain.
2006 CCLB
Laferty is offline
post #9 of 26 Old 04-22-2013, 03:13 AM Thread Starter
Everyone's heads, new or reman all come with the valves and springs installed? I misunderstood, thanks.
Important stuff:
frashdog is offline
post #10 of 26 Old 04-22-2013, 03:38 AM
Like a boss!
Laferty's Avatar
Unless specifically stated otherwise, yes.
2006 CCLB
Laferty is offline
