Finally the time has come- Mitch's truck build - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 104 Old 04-20-2013, 06:27 PM Thread Starter
Finally after being very patient this whole winter in waiting for parts etc etc. Mitch and I finally put his beast back to togethor. Here are a couple pics as to what it looks like. I think it turned out really nice and definetly looks mean under the hood. The truck is not finished 100%- it will be running tommorrow, Still need to finish the fuel system, change fluids, and she will run.
Steed speeds on, all I have to say is what a PITA! They are to put on. I dont think I have ever said so many cuss words trying to put these headers on. It might also be a problem that I have softball hands, not a good thing when trying to reach for those little Stainless bolts.
Steed speed up-pipes, ceramic coated and wrapped. These fit very well and was impressed with how they looked and fit.
Ported and polished intake manifold(ported and polished by mitch and welded by Adrian), stage 4 MTW turbo, all necessary parts, no limit cac tube, BPD intercooler, bpd 58v ficm with hercules 120 tune?, all installed. Notice a passenger side valve cover on the drivers side? Yup, custom ccv mod on both valve covers and also needed to run the dieselsite high pressure oil system.
Fuel lab fuel pressure regulator. This is the by far best place to mount the regulator, this is how mine will be mounted in my truck. Bracket was made by mitch- fits with the degass bottle mounting locations.
Finished product
Another shot before the air intake was installed
More to come tommorrow. Forgot to get pics of the intake manifold. Word to the wise on the manifold- be very patient and dont friggin rush the installation process- you drop a bolt in the intake? You do a head removal
bgraiders323 likes this.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #2 of 104 Old 04-20-2013, 06:48 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Looks good...but personally, I don't like where the fuel regulator is....to each their own tho. Not to mention....push lock hose was used... not a good idea IMO.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 104 Old 04-20-2013, 07:16 PM
Term3's Avatar
Quoted: 2 Post(s)
Agree with Strokin6L about the push lock connectors, but they are commonly used. Easy and fast to do but IMO really out of place with this great build when I would expect to see braided stainless steel hoses and stainless steel tubing. Did not realize Steed Speed were making their own up-pipes now. SUBSCRIBED!!!!!
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 104 Old 04-20-2013, 07:18 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Nice hopefully it runs good for him.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 104 Old 04-20-2013, 07:24 PM
snafu!'s Avatar
Is that hose tapped off the degas bottle coming from the back of the heads?
Looks good, bet you can't wait to get it running.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 104 Old 04-20-2013, 08:14 PM Thread Starter
That blue hose from the degas bottle is running to where the egr delete j-tube would go into. Push lok fittings are commonly used and those are top of the line fragola fittings with good hoses. Nothing wrong with this set-up.
bpd
Warren comp trans
04cr450 is offline
post #7 of 104 Old 04-20-2013, 08:18 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
A word of advice on the stainless braided comment, I will never run that sh!t ever again, everything it touches like have a belt sander under your hood. I redid my Dakota R/T with russell proclassic hose and red horse performance AN fittings. After using the proclassic hose and seeing the final look I could never bring myself to use stainless braided line on anything ever again.
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #8 of 104 Old 04-20-2013, 08:42 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Wanna see this thing running guys. I know I just met ya Mitch and Greg but still the anxiety is growing on that build. Haha
MrOneEyedBoh is offline
post #9 of 104 Old 04-20-2013, 08:50 PM Thread Starter
^I hear ya Anthony, thanks again for all the stainless nuts, bolts, hardware etc etc... Its a big help.
bpd
Warren comp trans
04cr450 is offline
post #10 of 104 Old 04-20-2013, 08:51 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 13 Post(s)
Looks fricken awesome man! I actually hit my regulator down under where you guys mounted it so the smog nazis won't see it out here.
Hopefully that beast runs good.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
