need help finding a tuner for 6.0 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-19-2013, 04:50 PM Thread Starter
Hey guys I'm most likely buying a 6l and I'm debating on a tuner. I'm leaning torwards the H&S mini maxx. I like being able to shift on the fly and if I buy any newer diesel I will probably be able to use it. I know a lot of people go with the sct. And I haven't heard much about the ppe tuner for the 6.0. So if anyone has used that feed back would be nice. And what you liked and didn't like about them. Thanks. I'm also curious if anyone knows about any other shift on the fly tuners for the 6l that are any good. Thanks
s10pete is offline
post #2 of 9 Old 04-19-2013, 07:44 PM
Dirty_Stroke's Avatar
Shift on the fly tuners are bad for the transmission in 6.0's. That is one reason most people go with SCT. If you feel the power difference between a custom race tune on the SCT and the performance tune on the other tuners and you'll know there's NO comparison.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 9 Old 04-19-2013, 07:50 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
what he said ^ my SCT Livewire TS 5015 is in the mail and on the way to me! i've seen trucks go from slow to incredible with just the SCT tuner..
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 9 Old 04-19-2013, 08:20 PM
thumper280zx's Avatar
sct all the way. i put my tuner on after my delete and you could feel the difference right off the bat. yesterday i took it off just to see if it was in my head and nope couldnt even wait to get home to put it back on and that is just with the street tune.
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #5 of 9 Old 04-19-2013, 08:48 PM
sprksonu's Avatar
dont waste your money with the h&s only reason newer trucks are going with them are for deleting the dpf system. get a sct livewire ts and be a happy camper then get custom tunes from matt at gearhead automotive or tony wildman
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 9 Old 04-19-2013, 09:00 PM
Street Dentist
stratotrev's Avatar
Got my SCT today, loaded my tunes and went for a good drive. I have to say, I love it. I don't think you can go wrong with the SCT when it comes to the 6.0. I'm new to the tuners too, but it sure feels good and seems like I made the right choice based on what I've read on here.
'06 F250 CCLB Lariat 4x4, 6.0, Stock Height, Destination A/T 285's, 4" MBRP Turbo Back, PMM Coolant Filter, EGR delete, Bilstein's, Scanguage II, SCT
stratotrev is offline
post #7 of 9 Old 04-19-2013, 09:21 PM
turbotibbo's Avatar
when i first bought my 6.0l i didnt no much about tuning . i went to the diesel performance store and bought the h&s mini max. i thought it was great lots of power and shift on the fly and all the gauges . after a few months the trans strated to slip and bang in to gear also known as the 3-5 shift flair , did some research on line and found out about the sct tuner and how it tunes the trans and h&s does not tune the trans on a 6.0l . so i still wanted to keep my mini max cause i liked the shift on the fly and the platform was great . i found out about the gogo direct clutch solenoid and that fixed my shift flair . then i found out a place called kem performance was working on building custom tunes for the mini max so i was pumped . but it never happened and now they threw the idea out . then i was waiting for the mcc to come out for the 6.0 l but never happend . finally i said screw it and bought an sct and loaded some custom tunes and i must say the shifting is like night and day , dont get me wrong the power with the mini was great and smoth but the sct is a better product for our trucks . i kept my mini max to use for gauges in case i decide to get a newer or different diesel . i hope this helps
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #8 of 9 Old 04-19-2013, 10:40 PM Thread Starter
Thanks guys I appreciate it. I think I will go with sct now. Any special version better than the others? And has anyone heard anything or used to ppe tuber for the 6.0 I'm curious about that tuner vs the sct. Thanks everyone!
s10pete is offline
post #9 of 9 Old 04-20-2013, 04:10 AM
5fifty's Avatar
I haven't used any other timers so I can't compare to much. But my setup is a SCT 3015 handheld for tuning the truck. For my gauges I am running an Edge Insight CTS. My tunes came from Matt @ Gearhead Automotive Performance. After my buildup, studs, injectors, Wicked Wheel etc.. I thought the truck ran great with the stock tune. After loading the custom tunes, it was a night and day difference.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
