EOT / ECT difference of 11 degrees - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-18-2013, 08:15 PM Thread Starter
Dene2006's Avatar
Hey folks. Just plugged in a new Insight CS and took the truck for a long run at 68 mph on a fairly flat, straight highway. The delta was 11 degrees. Is this alright or an indication of my cooler plugging. It is in the shop now for an EGR delete kit and new oil cooler but just wondering what your thoughts are.
Thanks
2004 F250 CCSB 2wd
SCT = Gearhead & Looney
MBRP 4" / S&B CAI
Borrowing money is like negotiating a pay cut for your future self...
Dene2006 is offline
post #2 of 21 Old 04-18-2013, 08:59 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Well if it's in the shop now for an egr delete and a new oil cooler it's pretty much a moot point, isn't it?
What was the ECT?
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 21 Old 04-19-2013, 06:16 AM Thread Starter
Dene2006's Avatar
What was the ECT?
If my failing memory serves correct, it was the one that was about 180 and the other was 190 to 191, but I'm not sure. It is a moot point but I was just wondering.
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #4 of 21 Old 04-19-2013, 07:48 AM
Dirty_Stroke's Avatar
Sounds like it was getting pretty clogged up. Your definitely doing right by putting a new one in while doing the EGR delete. Btw, I like the quote in your sig! Very true.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #5 of 21 Old 04-19-2013, 08:17 AM
tell them to put a new ford thermostat in there too. ect should be about 190-194 depending on outside temp. after all the work is done you should be withing 5 degrees of each other
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #6 of 21 Old 04-19-2013, 11:51 AM
DoubleDpsd's Avatar
You're fine. Beat the hell out of my truck can never get the delta past 11* split. Getting 20mpg.....why change my oil cooler?
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #7 of 21 Old 04-20-2013, 04:01 AM
elchaseo's Avatar
Quoted: 8 Post(s)
Just got off of work and doing 75 on the interstate my temps were 9-10* apart. Coolant being around 191 and oil around 200.
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #8 of 21 Old 04-20-2013, 07:30 AM Thread Starter
Dene2006's Avatar
Thanks for that tip on the thermostat. I'll let everybody know what the parts look like when he pulls them, (if they looked somewhat clogged etc.).
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #9 of 21 Old 04-20-2013, 07:40 AM
strokin6L's Avatar
Quoted: 4 Post(s)
i would do the thermostat first...that'll bring the ECT up and your delta temp should be right were it needs to be. Your oil cooler could be fine.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #10 of 21 Old 04-20-2013, 07:43 AM Thread Starter
Dene2006's Avatar
It's in the shop now for the delete kit anyway strokin6l. We RV during the summer months so hopefully that will be one less thing to worry about. It might even be done today, can't wait, he says it could possibly even idle / run better because of not pumping spent gasses back into the motor. Got the blue spring put in to and he really says that is a stupid mod for anyone under 500hp.
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
