off with the Pmax and return of the stocker. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-17-2013, 06:17 PM Thread Starter
This is more of a test than anything since I didn't get to test my Banks IC with the stock turbo. you can see my test (here) which I'll be adding to. First I want to say I like the Pmax+Batmo combo I haven't had any issues and mileage with ID's FICM and street tunes has been between 15.5 city/21hwy (hand calculated). Off idle response is down a little but not bad noise soso depending on my mood. Now for the stock turbo it is now being tested on the truck with studs and all new injectors same as the pmax. I will update the other thread with temps when I get them tomorrow. As for mileage before the IC and Pmax on the stock stuff on ID's FICM and Street tune was 16.5/21(althought it might have been better since it had issues when I got this number). Ok some meat for you to look at.
ID's Moderate FICM and street Pmax tune for the Pmax+Batmo +Banks IC
WOT 28PSI EGT's 1160*F
ID's Moderate FICM and Street tune for the stock turbo +Banks IC
WOT 22PSI EGT's 1350*F
I have a feeling the low boost was do to the large IC and piping. I can say air temps are up. Also tire wear is going to be a issue again something I have had much of with the Pmax. With the Pmax I could light the tires easy but with the spool delay it helped. Now this thing lights the micro second you step on it and leaves black marks even with out trying. Even thought the boost is low it still pulls hard up top. Anyways I'll update the other thread tomorrow night. Once this is done if the mileage doesn't gain a lot the Pmax with be going back on maybe even with MTW's single plain wheel for some testing.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #2 of 4 Old 04-18-2013, 12:28 AM
kdogg85's Avatar
Guess the different turbine makes a difference, wonder how your pmax would do with the 13 blade vs the 10 blade? Good luck, hope it works out for you.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #3 of 4 Old 04-18-2013, 03:28 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I installed banks IC and gogo intake at same time with no other mods and I actually seen a small rise in boost pressure, I don't know why. I remember because I was extremely concerned during the install the turbo wouldn't be able to fill all the extra room, but instead it boosted about 2-3psi more. Must be do to the smoother path of airflow. Just a data point for you.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 4 Old 04-18-2013, 09:21 PM Thread Starter
you know the funny thing is today I returned the truck to stock and I got 27psi and that was even with the EGR enabled. I don't know what is going on with that. But I do know this weekend the Pmax is going back on. With the Pmax I like the fact I get a cooler change at the same PSI also I can run higher power tunes with lower egts. As for power once the tune had time to learn it lost some of the bottom end and I could tell much difference down low between the Pmax or the Stock turbo. But I can tell a difference mid and on the high end. Also a strange thing I notice was I get more lag with the stock tune with the stock turbo than with the pmax and stock turbo. I know some don't like the Batmo but I did notice a difference and for the good with my setup.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
