Installed my ww 2 yesterday - Ford Powerstroke Diesel Forum
post #1 of 30 Old 04-17-2013, 01:43 PM Thread Starter
Well guys I installed my wicked wheel from diesel site yesterday and so far I love it! To start this is the first time I have ever pulled my turbo or even really removed much on the truck. Pulling the turbo was pretty easy I got it out and on my bench, I couldn't get the damn thing part. After pounding on it and getting the damn thing apart I it was rusted good and very hard to pull the exhaust side apart I found that the nut part on the shift, that looks like is there to hold the shift still when taking the compressor off was damaged and rounded off. After Messing around with different socket sizes I was able to hold it with pliers and get the stock compressor off. I installed the ww and cleaned the exhaust side good and made sure there was no damage or anything I put it back together and started my reinstall. Needless to say that putting the turbo back in was a *****!! I tried for 20 minutes and had to take a break to cool off... Lol it kept getting hung up on the damn drain tube. Anyway I got it in and l buttoned up and I was worried it would even run... Lol started up and ran fine. I took it out for a test drive and started smelling burning oil so I pulled over and looked under truck and had a **** ton of oil pouring on the ground. I debated on calling the wife to come get my truck and I but realized I left my phone home! So I drove it home leaving a trail of oil behind about 3 miles. I get home and start searching for the problem when I shine a flashlight under the driver side turbo and I see the damn drain tube was pulled out of its home and stuck just letting oil drain out onto the engine. After cussing and throwing a tantrum I dug back into it and got it placed back in its home and now everything is working well.
My exhaust temps are about 75 degrees cooler and I love that it does spool quicker and I'm interested if I will gain any mpgs but so far I can say it was worth the 239 dollars I spent on it :-) I'll keep you all updated
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #2 of 30 Old 04-17-2013, 02:44 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I thought i had experienced just about anything that can happen to R&R'n the Turbo, but I never did that 1.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 30 Old 04-17-2013, 02:52 PM
Koda22's Avatar
Quoted: 5 Post(s)
Like hearing stuff like this....the goods and the bads...I keep thinking I'm gonna order one but never pull the trigger....I think it seems like a great upgrade for the price...
Koda22 is offline
post #4 of 30 Old 04-17-2013, 02:53 PM Thread Starter
Ya I can say I learned a lot and it was quite fun and easy digging into it... These engine e's are surprisingly easy to work on if you don't mind a few busted knuckles and bruises.
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #5 of 30 Old 04-17-2013, 02:57 PM Thread Starter
I honestly would say it's worth the price so far for a cheap upgrade that is noticeable especially on the low end... I'll be towing with it pretty soon so I'll let you know how it does.
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #6 of 30 Old 04-17-2013, 04:41 PM
Koda22's Avatar
Quoted: 5 Post(s)
Yea would love to hear, don't tow a lot but he little I do any help would be great
Koda22 is offline
post #7 of 30 Old 04-17-2013, 05:58 PM
5fifty's Avatar
I have been towing with mine and it did indeed make a difference in the spool up. I didn't have my Edge Insight installed before I put it in so I do not have any numbers to compare.
It will clear up 155/30 injectors even with a stock tune.
For the price it is a good deal IMO. IT will not take the place of a larger turbo if that is what you are truly needing. But for less than $250 and a half hour of time it is well worth it
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #8 of 30 Old 04-18-2013, 05:36 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Glad to hear its working out for you and that you were able to get the oil leak fixed quick too.
The results sound identical to our (MTW's) wheel.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 30 Old 04-18-2013, 07:15 AM
joe blow's Avatar
Quoted: 23 Post(s)
Man you got lucky with the oil leak. When I rebuilt mine it fought me for sure, and it doesnt help it is so heavy and shoved in a small hole either!
I read in your sig you have an '04.......I have an '04 but dieselsite told me they didnt make one for my year as of yet.....what is the build date on your truck?
Thanks
joe blow is offline
post #10 of 30 Old 04-18-2013, 07:41 AM
Dieselsite Barbie's Avatar
Thanks
The 2004 has two different versions... an early and the late.
Our current wheel works in the 2004.5-2007.
For fun:
I've learned quite a bit since I've started working here full time and one of the more interesting things about the 6.0L's I've learned is that I have to look at them as 3 different trucks:
2003 - Early 2004
2004.5
2005-2007
Crazy stuff!
Dieselsite Barbie is offline
