Price Check? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 04-16-2013, 07:58 PM Thread Starter
Price Check?
Looking for a price check on parts and labor for an EGR Delete.
I have searched google and this website and I am getting price ranges from $600-$1,600...
For $1,600 id just do it myself.....
I am located in North Georgia near Chattanooga so I do have access to both the Atlanta, Chattanooga, and Knoxville area.
Anyone have any information on Powerstroke Specialty, LLC located in Buford Georiga? This is his website as he seems to be an EXPERT on these trucks. Also having multiple informational videos online (powerstrokehelp.com)
If anyone has any recommendations for my area I would greatly appreciate it.
souther32 is offline
post #2 of 24 Old 04-16-2013, 08:00 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Wow that seems spendy. This is a very do it yourself kinda job. If you have ever tinkered with motors you can do this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 24 Old 04-16-2013, 08:10 PM Thread Starter
Yeah I have a designated shop to spend some hours working on this. I'm just trying to see if it would be worth my time and effort... or just pay someone to do it
post #4 of 24 Old 04-16-2013, 08:14 PM
rdunagan's Avatar
i normally charge 1200 to do it but thats with a oil cooler as well
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #5 of 24 Old 04-16-2013, 08:21 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1618 Post(s)
You have more then most of us...should just try it yourself. It a great learning experience for these engines. As for the price check, I charge 500 but that includes the EGR delete kit.
toren302 is offline
post #6 of 24 Old 04-16-2013, 08:50 PM
adamread's Avatar
You should look at IPR's 2nd gen kit, that's what I would go with if I were doing it over.
IPR EGR GEN2 Delete Kit with Up Pipe & Gaskets for all 2005-2007 Ford Powerstroke 6.0 will fit F250, F350, F450
2006 F250 CCSB - Full PMF Suspension (3.5" 3-Link, 5.5" Traction Blocks, Drag Link, Track Bar & Steering Stabilizer) Bilstein 5100s, Hellwig's F+R, Centramatics, 20" Harleys, 35" Cooper Disco STTs, Nuc Bypass, Marine Charger, DDEC60 Block Heater, ARB w/ HID Hellas, BPD Water Pump, 5" MBRP Straight, SCT-X3 w/ IDP, H11's w/ OEM Gaskets
Dead in Water - Blew Turbo / IPR
adamread is offline
post #7 of 24 Old 04-16-2013, 09:11 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Stay far far away from Bill Huitt and Powerstrokehelp.com. You've been warned.
Couldn't agree more.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #8 of 24 Old 04-16-2013, 09:24 PM
rdunagan's Avatar
irp egr delete is the shizz nit! its all we use at the shop!
rdunagan is offline
post #9 of 24 Old 04-16-2013, 09:33 PM Thread Starter
$500? Now we are talking... Where are you located haha
Anyway, if I purchase this IPR EGR Delete Kit and take it to a shop, will they know what and where all the pieces go? Just making sure before I make any buying decisions.
What is the difference between these two products?
IPR EGR Delete Kit with Up Pipe & Gaskets for all 2003-2004 Ford Powerstroke 6.0 will fit F250, F350, F450
I notice that the year model is different and one is the first and one is the second generation.
My truck is a 2005 model but was built in early 2006
Choose Kit With Up Pipe or Exhuast Block Off Plate???
post #10 of 24 Old 04-16-2013, 09:51 PM
adamread's Avatar
Q1; If you manage to find a shop that can't get this figured, run as fast as you can.
Q2; Wow, I can't believe they are the same price, you would have to be a mental patient not to get the gen 2 if they're the same cost.
Q3; The block off and the up pipe perform the same purpose, adapting the system to run w/o the cooler. Once you no longer have the cooler, there would be a tee with a few inches of pipe blocked off (assuming you use the blockoff) en route to the turbo. Works fine I'm sure.
The perfectionist in me sees that tee causing turbulence and decreased efficiency/performance over a replacement straight pipe (up pipe). But in 99% of applications it probably doesn't matter. Other than the fact that you then have one more connection (and possible exhaust leak point) on said pipe instead of the replacement w/o.
Block off plate is easier to install.
I'd get the Up Pipe without really even considering the other.
adamread is offline
