Drop Pitman Arm needed 6" Lift - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-16-2013, 07:39 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
I have 1, what does it fix and is it necessary?
Death Wobble ?
Bump Steer ?
Re-alignment necessary if i swap it out keeping everything aligned and in place? I'm sure the drag link will need to be shortened up but everything else should be fine correct?
ICON 4.5" Lift + 2" Spring spacer under pad.
Extended the Drop links, extended the shocks,
TIA
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 4 Old 04-16-2013, 09:11 PM
I'm not 100% sure what you're after here, but here's what I think you're looking for:
*Death wobble is usually the need for a steering stabilizer (or better shocks I can't remember exactly which) in a coil sprung Souper Doody.
*Bump steer is from a misaligned steering system, ie a lift without a dropped pitman arm.
*While the camber and toe was most likely unaffected by the lift, the caster needs to be checked after lifting a 2005 and up truck.
*If that lift/spacer are installed without adjusting and/or lowering the trailing arms, see the statement about caster.
*Extended sway bar links will allow the sway bar to work properly. Same for installing longer shocks.
I hope this helps.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 4 Old 04-16-2013, 10:49 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Death Wobble ?
Bump Steer ?
TIA
Denny
A drop pitman arms purpose is to lower the steering angles to prevent bump steer and so is a drop track bar bracket. Your drag link when it gets kinked on the tierod ends cause major bump steer when you hit a bump and can cause a death wobble. You always need to have the draglink and trackbar at the same angle.
My draglink is custom with 1 3/4 heim joints and the ball joint on the axle is flipped so my angles can be perfectly the same. No bump steer at all. You must run a drop track bar bracket and pitman arm on a 6in lift.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #4 of 4 Old 04-17-2013, 06:58 AM Thread Starter
Quoted: 2 Post(s)
Cool, thanks you nailed it.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
