Upgraded injectors? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-16-2013, 02:29 PM Thread Starter
Mwhitt002's Avatar
Upgraded injectors?
I am in need of injectors and someone I know at work will do them for cheap. I was wondering if I could run aftermarket ones and maybe a new turbo without head studs?
Sent from AutoGuide.com App
2006 F250
8'' Rough Country lift, 38'' Toyo Open Oountry M/T, 20'' chrome Rockstars, Edge Insight, S&B Intake, SCT innovative tunes, Dual 6 inch stacks
Mwhitt002 is offline
post #2 of 2 Old 04-16-2013, 02:56 PM
Yup. Try 175/30's with a powermax or mtw stage 1 with a billet wheel. There are other combos you could do, but the one I mentioned should be a good one for sure. Im doing the same combo here shortly
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
