GOGO Soleniod and Shifting - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-15-2013, 12:02 PM Thread Starter
Aretoo's Avatar
About 2 weeks ago it was time to flush the tranny "since I was in there" i decided to do the 08 pan and filter upgrade. About 2 weeks before I did it i began to get a little bit of a 3-5 flair. With new fluid, filter change, and the GOGO it is running and shifting great.
One question I have is how hard is too hard for a shift. There is no flair now with the 3-5 shift. If I am getting on it through the shifts it shifts smooth. If I am driving like my wife, the 3-5 shift is pretty firm, maybe borderline too hard. how hard is too hard for a shift. I know some of the guys have turned down the shift pressures to help with it.
For you guys that have done that how much have to turned down the pressures?
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #2 of 12 Old 04-15-2013, 12:54 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 134 Post(s)
Feedback Score: 3 reviews
I have experienced the same thing with my solenoid. I just live with it. Maybe talk to Matt and see what his take on adjusting the tuning.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 12 Old 04-15-2013, 04:11 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Turn it down in 5% increments until you are satisfied with the shifts.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 12 Old 04-15-2013, 04:27 PM Thread Starter
Aretoo's Avatar
Thanks for the advice. I wanted to make sure I was not going to make too much of an adjustment first.
The shifts really don't bother me, I was not sure if shifting that firm was OK for the tranny.
MODS
ARP Studs
IPR Gen2 EGR Delete
MBRP 4" turbo back
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #5 of 12 Old 04-15-2013, 05:30 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
I wish i had this problem!!! lol
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 12 Old 04-16-2013, 03:30 AM
turbotibbo's Avatar
I had my gogo for a while now and no bad effects at all the only thing I don't like is some times in town it will down shift kinda hard from 5-3 . I believe the faster and firmer the shifts the better . I read somewhere ford tried to make the 5r110 shift like a car would soft and not noticeable . I would rather have It shift hard then soft and slipping
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #7 of 12 Old 04-16-2013, 06:46 AM
Soft/spongy shifts are the worst thing for an automatic transmission. Mfrs have been catering to the masses for so long that we think that firm shifts are hurting something somehow.
As previously stated, play with your shift points if it's a concern. Until a shift makes the Tow/Haul light flash, it's fine.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 12 Old 04-16-2013, 07:14 AM
colonel angus's Avatar
Quoted: 2 Post(s)
i just completed this mod. too. changed the 3-5 sol #7 and the Reverse Chatter sol #6 both in the 3 row of solenoids.
Upgraded to the 08 pan and filter and changed the frame rail filter -we all know how that went...
Did you notice you have more fluid capacity with the 08 pan? i put 9 Qts. back in but find reading the dip stick a bit tricky.
Mine shifts fine for my taste hard and fast that's i how i roll..
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 12 Old 04-17-2013, 06:42 AM Thread Starter
Aretoo's Avatar
Well from reading what everyone said I think I am going to leave my shift pressures alone. It does not bother me the way it is shifting as long as it was not going to hurt the tranny. The faster I get through the gears the smoother and firmer it shifts.
Guess I will just have to drive that way more often.
Thanks for the help.
MODS
ARP Studs
IPR Gen2 EGR Delete
MBRP 4" turbo back
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #10 of 12 Old 04-17-2013, 03:57 PM
1fastTRX's Avatar
I had my shift pressure turned up 25% with my old solenoid to help shifts until I swapped in the gogo solenoid. After I swapped solenoids I just left the shift pressure at +25%. Its fine for me so far, but I just swapped solenoids on saturday
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
