Aluminum Degas bottle - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-14-2013, 06:21 PM Thread Starter
brscott38's Avatar
After building my custom intake I had rerouted the coolant back to the degas bottle instead of through the intake. When rerouting to the degas bottle I did not want to restrict flow out of the oil cooler by going to a 3/8 hose. I wanted to keep the 3/4" hose coming out of the cooler so I decided to build a custom degas bottle that would allow me to run the 3/4 hose. Here are a couple pics
Sent from my SPH-L710 using AutoGuide.Com Free App
ID:	97138   Click image for larger version
brscott38 is offline
post #2 of 17 Old 04-14-2013, 07:05 PM
Glueballs's Avatar
Any pics of the intake? I'm a decent hand at aluminum and I'm trying to decide to cut and modify the OEM intake or to build a custom one. When I tear into it this summer to bulletproof it I want to have as much parts as I can. Planning on doing all the prep for Compounds and then do them and injectors next year.
Greg
"You are not thinking. You are merely being logical."
Niels Bohr
06 F350 Amarillo CCSB - MODS - Bulletproof 6phase FICM 58V, Odyssey 65-PC1750, SCT iTSX Tuned, EGR delete, 4" with Cat and Muffler - To be installed - Bulletproof Oil Cooler, Regulated Return w/ fuel bowl delete and FASS.
Glueballs is offline
post #3 of 17 Old 04-14-2013, 07:12 PM Thread Starter
brscott38's Avatar
ID:	97194   Click image for larger version
post #4 of 17 Old 04-14-2013, 07:14 PM
jetjock15's Avatar
Quoted: 110 Post(s)
Dude, sweet aluminum work! I run the gogo manifold that directs coolant direct back to degas though 3/8 line. Many of us running it for years with no issues. That's a low pressure system. Nice degas tank though!
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 17 Old 04-14-2013, 07:19 PM
Glueballs's Avatar
Nice job, what are you sealing the coverplates with? I was thinking of using Orings but you would have to have enough material available for the groove. I'm going to pick up one from the Scrap Yard and see what I can do. When you said custom intake. I was picturing the $4000 ram air one elite sells.
Greg
Niels Bohr
post #6 of 17 Old 04-14-2013, 07:20 PM Thread Starter
brscott38's Avatar
Thanks. I know there are people running the 3/8 hose with no problems but I didn't like the idea of cutting the flow in half. It also gave me reason to build a cool tank
post #7 of 17 Old 04-14-2013, 07:22 PM Thread Starter
brscott38's Avatar
Yes I'm using orings
post #8 of 17 Old 04-14-2013, 07:29 PM
fordpwrstroke7's Avatar
Looks very cool. Have you pressure tested it yet?
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #9 of 17 Old 04-14-2013, 07:37 PM
jetjock15's Avatar
Quoted: 110 Post(s)
This was a concern of mine also but when I run it (at least at idle) the flow is pretty much a trickle through the 3/8 line. At higher rpm it may be more though? But I have had truck runnin and directed flow into a bucket and it just dribbles out. Probably higher pressure at higher rpm.
post #10 of 17 Old 04-14-2013, 07:43 PM Thread Starter
brscott38's Avatar
Yes i have been running it for the last couple of days
Jetjock that's interesting to know I never really tested the amount of flow seems like there would be a decent amount of flow even at idle
