Installed wicked wheel now higher egts? - Ford Powerstroke Diesel Forum
post #1 of 54 Old 04-13-2013, 05:44 PM Thread Starter
Stumppy's Avatar
I installed my wicked wheel last week and have been running my truck all week with it. I've noticed my egt's are now running about 100 degrees higher than normal and climb very fast. I can hit 1300 just getting on the freeway. Any thoughts on what the problem might be? I don't have an exhaust leak and the turbo is seated in the y pipe. Debating on taking it back off and installing my stock wheel again so I can pull my camper this next weekend.
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #2 of 54 Old 04-13-2013, 05:48 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
I have no idea, But im curious too, cause this is going to be one of my udgrades when i bullet proof my truck.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 54 Old 04-13-2013, 05:52 PM Thread Starter
Stumppy's Avatar
There's times at around 3 psi it almost sounds like its rubbing but its very faint and only at that psi and not all the time. It says it is building boost fast and the truck hauls azz just higher egt's then I'm used to seeing.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #4 of 54 Old 04-14-2013, 10:02 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Maybe that wheel flows more air but spools a tad slower. This will cause it to be slightly rich right as you get on it, and the turbo is playing catchup. Try having your tuner pull a little fuel down low. Once the EGTs start to rise they stay hot. For example when I run one of my tunes meant for my 155s the EGTs are good. When I run one if my tunes from stock injectors my EGTs are high. They both command 100% fuel on top, but the 155 tunes pull some fuel on bottom. But because the EGTs got high right off the bat, they stay about 100 degree higher all the way up to and continue at WOT. That all just based on my experience and observation - food for thought.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 54 Old 04-14-2013, 10:22 AM Thread Starter
Stumppy's Avatar
I will talk to Matt tomorrow and have him pull fuel down low and see if that helps. Today going 70 down the freeway my boost was 5 psi and my egt's actually were low around 680 which is the lowest Ive seen on my truck on the freeway. But getting on the freeway it hit 1338. So they are everywhere right now.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #6 of 54 Old 04-14-2013, 10:35 AM
DoubleDpsd's Avatar
glad I dont monitor egt's.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #7 of 54 Old 04-14-2013, 10:38 AM Thread Starter
Stumppy's Avatar
Why don't you monitor your egt's?
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #8 of 54 Old 04-14-2013, 10:58 AM
HMM
HMM's Avatar
Quoted: 2 Post(s)
I haven't noticed that. I'll keep an eye on mine and see if I see the same thing.
2006 Dark Shadow Gray Harley #898
HMM is offline
post #9 of 54 Old 04-14-2013, 11:31 AM Thread Starter
Stumppy's Avatar
Let me know what you find out. Maybe I just watch my egt's too close. I hate it when i start to see 1100 towing up grades lol.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #10 of 54 Old 04-14-2013, 12:08 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
My turbo was all stock when I came up to Alaska with stock programming, stock injectors and I would see 1300* on 10% grade hills. You're probably just paranoid but I would inquire about pulling fuel on the low side anyways.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
