6.4 cam in 6.0 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2013, 08:59 AM Thread Starter
powersmoker's Avatar
6.4 cam in 6.0
is it possible to put a 6.4 cam and lifters in a 6.0. what is needed for the swap are there any performance gains.
1999.5 ford f250
DIY INTAKE
TS CHIP
TNBB TURBO
4 in straight pipe
6 in lift and 35 at
soon to come
stage ll injectors
powersmoker is offline
post #2 of 8 Old 04-12-2013, 10:39 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I believe that the 6.0 and 6.4 motors use the same cam. At least RCD sells their cam kits as a 6.0/6.4 cam.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 8 Old 04-12-2013, 12:52 PM
OP what would be the benefit of this?
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #4 of 8 Old 04-12-2013, 03:22 PM Thread Starter
i have no clue i have heard they will fit just wanted to see if there is any gain from doing it. my cam plate is wearing on my 6.0 and wanted to see if i can just replace it with a 6.4 cam set up
post #5 of 8 Old 04-12-2013, 04:45 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
By the time you pay to pull the motor and tear it all the way down plus rebuild it with a new cam it would be cheaper to drop a new long block in it and call it good.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 8 Old 04-13-2013, 07:17 AM
shawnb99's Avatar
i dont believe any gains would be had with a stock 6.4 cam being it is more related to emissions.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #7 of 8 Old 04-13-2013, 07:41 AM Thread Starter
i have done a lot of 6.0 work. and have 3 differant lifts to use at the shop i work at. so labor is only my spare time was going to do it when i stud the truck
post #8 of 8 Old 04-13-2013, 06:28 PM
lubeowner's Avatar
They are the same. The American Ride has a cam in it out of a 6.0 engine.
lubeowner.com
Get the best prices on 6.4 dual fueler kits, 6.0 and 6.4 nozzles and ported intake manifolds for the 6.0 and 6.4.
lubeowner is offline
