question on lowering heavy tow egt's and ported intake - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-11-2013, 03:50 PM Thread Starter
Garage
I tow heavy with my truck usually 16-22k, looking into lowering my egts as much as possible before resorting to water injection.
I've searched about these intake manifolds but most ppl are talking hp, which is a great plus, but will egt drop from more air flow especially to rear cylinders?
Any tow tune suggestions? Currently using vivían tow tune which helped drop egt about 100deg now avg 1100-1250 up steep grades at 25-30 boost with powermax
Full '08 Front conversion w/tails
Oil-less AirRaid/Blue Spring/PowerMax/4" D/P to tip/Vivian SCT Tow Tune #30/19.5 w/245/70
EIAutoTransport is offline
post #2 of 11 Old 04-11-2013, 05:04 PM
I do not tow heavy, but for my truck a ported intake helped to drop my temps 150 degrees. If it was my truck I would throw a Spearco intercooler, No limit intake elbow, and ported intake from Diesel Dr. at it and see what you got. You might be able to turn up the fuel a little after the mods.
svilla is offline
post #3 of 11 Old 04-11-2013, 05:23 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would do a ported intake manifold WAY before I did an intercooler. They're cheaper and actually offer more performance (i.e. power, EGT drop, higher fuel economy, etc).
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 11 Old 04-11-2013, 05:26 PM
The Silent Service
colo_dually's Avatar
Quoted: 12 Post(s)
Everything I've read, there is a greater cost to airflow gain with a ported manifold (when compared to an IC). The question is how much of the original emissions control equipment you want to maintain. Most of the shops porting out mainfolds take all emissions gear off them (hard to pass a visual that way, let alone a full emissions).
I'd like to recommend one to you, however, all the companies I've ask remove the EGR cooler and valve.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 11 Old 04-11-2013, 06:15 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Ben, I'm not sure where/who you've been asking about ported intake manifolds, but I know Diesel Dr and myself can build them with the EGR portion still in place and they do not cost anywhere near what an aftermarket intercooler costs. I know a ported intake manifold from them with the EGR stuff still in place goes for $500. I don't even think a POS Mishimoto IC can be had for that price. Even the one with the EGR portion removed only costs $700 from them. Now I will admit that the gogo, apex, and (I believe) Elite manifolds are all as you mentioned.
Nate
post #6 of 11 Old 04-11-2013, 06:43 PM
I agree however, I think the combination of parts will allow him to add a bit more fuel to it, pick up a little power, and keep his EGT's in check.
I guess I should have asked about budget. But yes, if you were to do only one mod I would do the ported intake manifold hands down before all the other mods.
svilla is offline
post #7 of 11 Old 04-11-2013, 07:27 PM
bondajb's Avatar
does 1250 make you nervous? I pull a 17k lb 5th that is 13'4" and will hold 1375 as long as required. there are 3 of us running these temps. no burn downs yet. I would love to see 1250 as a max but then would add more fuel and be back to 1350. My water meth doesnt help much with temps. I am porting my own manifold to see if that helps this season.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #8 of 11 Old 04-12-2013, 04:12 AM
jetjock15's Avatar
Quoted: 113 Post(s)
I added a gogo intake and Banks Intercooler at the same time to lower temps not increase power. Adding those two mods at same time netted 150 degree drop in EGT across the board. Don't know the breakdown of how much each contributed, I installed them both at same time. On stock sticks after adding those parts I could not get my EGT to break 1150, ever. Same tunes before hit 1300. Now I've added bigger injectors which have up'd my EGTs. They are new and I have not towed yet, but I know EGTs will once again become an important part of my monitoring.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 11 Old 04-12-2013, 05:01 AM Thread Starter
Garage
Thanks guys for all the info to look into, definitely will be doing the ported intake after all the personal feedback I just read and look into an intercooler/no limit elbows soon as well. Possibly additional electric fans for hot days to aide in lower ECT/EOT temps, right now on 70deg can hit 225ECT uphills.
bondajb it doesnt make me nervous, if you didnt notice this isnt my drive around town or vacation hauler type of truck, I have 2 light duty fords with 3/4car trailers and one 7car freightliner with red-top 525HP N14L cummins that all play there part in keeping my business rolling and 4 employees paid.
So I expect all my equipment to last as long as it can with very minimal downtime, even a single day of downtime can cost me thousands out of my pocket. Especially this green '04 I just got on the road 6-7mths ago with 160k which today already broke 215,000miles it averages 3-4 trips a week at 1500+miles and 12-18hr days running.
post #10 of 11 Old 04-12-2013, 06:43 AM
bondajb's Avatar
I put a amsoil dual filter bypass and the largest filters they offer.. 2qts each, with that much capacity it acts like a second oil cooler..
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
