Egr delete recommendations? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-11-2013, 11:03 AM Thread Starter
Finally got the motor back together after roller lifter failure in 2006 f450. Where is a good place to buy a when delete kit? Is there a particular kit you recommend ? I'm pretty sure I will also need a tuner. Any suggestions? Id like to do it before I put the motor back in.
Caterpillar Level 3 Diesel Tech
1991 Ford F250 7.3 IDI
All aluminum radiator
1 ton axle and suspension
dually wheels
koenig rawson tool bed
billet grille
HID headlights
clear corners
Custom 1/2" thick front brush guard/bumper
1991 F250 7.3 IDI
Awaiting 5 speed transmission swap and banks turbo install.
DieselMechanic87 is offline
post #2 of 20 Old 04-11-2013, 01:18 PM
Dirty_Stroke's Avatar
I have the Sinister EGR delete kit on my truck and it fit great. However I've installed EGR delete kits off of eBay on other 6.0's without any issues and they was about $200 cheaper than my Sinister kit! I say get a kit off eBay. Just make sure you get one that has everything you need. They all do the same thing. No sense in paying for a name.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 20 Old 04-11-2013, 01:19 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
We can get you setup with an EGR delete kit and some tunes. You can check out all of our 6.0L stuff HERE.
Do you already have a programmer?
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 20 Old 04-11-2013, 01:54 PM
licenced2burn's Avatar
I used the Rcd kit and so did my friend they are about 200$ on eBay and fit great. Had mine on for 2 years and no problems.
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #5 of 20 Old 04-11-2013, 04:17 PM
rdunagan's Avatar
IPR kit for sure! 1 solid piece and no leaks! about the same price as a sinister
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #6 of 20 Old 04-11-2013, 04:59 PM
5fifty's Avatar
I got a Performance Machine EGR Delete kit along with a SCT x3 3015 tuner from Thoroughbred Diesel for I think it was $479. It was a package deal.
I would have gotten the IPR one but it wont work with the BPD remote oil cooler.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #7 of 20 Old 04-11-2013, 06:36 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Hands down the best egr delete on the market. The only one I recommend at this point.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #8 of 20 Old 04-11-2013, 06:38 PM
SnoracerX's Avatar
Ill vote rcd the fitment is great
SnoracerX is offline
post #9 of 20 Old 04-11-2013, 06:42 PM
USAFBowman's Avatar
I third IPR Research for EGR delete, I just put one on my truck. As for a tuner go with a SCT handheld.
Also if you dont have it already get a monitor. I love my Edge Insight CTS
USAFBowman is offline
post #10 of 20 Old 04-11-2013, 09:30 PM
rdunagan's Avatar
only ones ill put on anymore! fixing to do a few more this weekend actually
rdunagan is offline
