best size injectors for powermax?? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-10-2013, 03:43 PM Thread Starter
jimmyz32's Avatar
I am considering going backwards. I am wanting to trade my 190/75 injectors for something better suited for my powermax. what is the biggest injector a powermax can clear up?
2004 F250 4x4
1) head studs
2) 4" turbo back exhaust MBRP muffler
3) super expensive built transmission
4) leveling kit and 3.73 gears with a locker
5) Full EGR delete
6) Air Dog 2 165
7) full set of gauges
8) ladder bars
9) smoke switch (I Don't use it)
10) eliminated banjo bolts for 90 degree fittings
11) tuned by lots of people
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #2 of 20 Old 04-10-2013, 05:38 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
Why not get a ported intake manifold?? Get some live tuning and it's going to run great.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 20 Old 04-10-2013, 06:43 PM
kTm520's Avatar
^^agreed. My 190/100's rip with my pmax matt at gearhead tuned it well. It's not that smokey or hot and i tow a horse around too
2005 King Ranch, arps, oem gaskets, pmax, 190's/100's bu warren, egr delete, 5 inch exhaust, sct tuned by quick tricks/innovative/gearhead, suncoast trans, custom paint work work
kTm520 is offline
post #4 of 20 Old 04-10-2013, 07:58 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Poor horse. 175/30's get my vote and put an MTW 11 blade billet compressor wheel in it.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 20 Old 04-10-2013, 09:48 PM
madpowerstroke's Avatar
Everything you have done so far sounds good. I would have to know about your truck and what you want, how clean you want it? Once you port the heads things change a little as far as what you need to consider. I would have to know how much porting and how much are the heads flowing over stock to help you out. Might have to get other parts to help your combo work good. Without more info it's hard to tell you what injectors to use.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #6 of 20 Old 04-11-2013, 02:52 AM
kTm520's Avatar
Id really like to strap adrians stage 3 to my truck and see how it runs!
kTm520 is offline
post #7 of 20 Old 04-11-2013, 04:03 PM Thread Starter
jimmyz32's Avatar
I have a tune from Matt he has turned the injectors down it
Does not smoke bad. It just as soon as I pull anything even a
Empty 14' light trailer and go over a hill my EGTs go up to 16-1800
Just trying to keep the same speed. I have talked to several tuner guys
And they mostly say put it back to stock if I want to keep the
EGTs down or keep my foot out of it. I am getting very frustrated . I was
Planning on getting a ported intake. Then I was told it would not make
The difference I want. I just don't want to have watch my gauge more than the
Road.
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #8 of 20 Old 04-11-2013, 04:14 PM Thread Starter
jimmyz32's Avatar
The heads have had the exhaust side opened up
The intake side was cleaned up and the swirl pattern was improved
The valves were 3 angle cut that is all I can remember
I did notice a big difference in acceleration
In the mid range.
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #9 of 20 Old 04-11-2013, 04:24 PM Thread Starter
jimmyz32's Avatar
How do I post a video
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #10 of 20 Old 04-11-2013, 04:44 PM Thread Starter
jimmyz32's Avatar
I can't seem to post a video from my phone
I could have the head work backwards it was a while back
I have talked to guys that have no problems with
EGTs getting to hot and have more power than me
I think I am only at 550 to 575 hp at the most.
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
