Passing Air Care - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-09-2013, 08:54 PM Thread Starter
Dene2006's Avatar
Passing Air Care
I don't know what the correct term is for having your vehicle checked for proper emissions etc. Up in Canada we don't have to many areas that reuire it I believe.
My '04 Powerstroke has tunes by Vivian and Gearhead, both provide more power than I could imagine. The exhaust sounds like a blowing air compressor out the tail. So much air at idle it would believe me to believe I would easily pass the air care test. I have a muffler but no cat and next week it goes in for the EGR delete kit.
Would I pass the test if I had to take the truck in please?
Dene
2004 F250 CCSB 2wd
SCT = Gearhead & Looney
MBRP 4" / S&B CAI
Borrowing money is like negotiating a pay cut for your future self...
Dene2006 is offline
post #2 of 7 Old 04-09-2013, 09:16 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
When I pass air you don't want to be anywhere around.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 7 Old 04-10-2013, 11:19 PM
You might need the cat to pass the visual inspection, they looked under the truck for me last time, but not under the hood. No egr, hollowed out cat, and stock tune was a very clean pass for me last time.
Phil
phil_phil is offline
post #4 of 7 Old 04-11-2013, 12:04 AM
jmeaby's Avatar
Quoted: 16 Post(s)
if they look for the egr cooler or valve you can pull the egr cooler and put freeze plugs in each end to make sure that nothing gets in
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #5 of 7 Old 04-11-2013, 08:13 AM Thread Starter
Dene2006's Avatar
Phil
Thanks Phil. Other than visual inspections, do you think the emissions would pass because of all the air going out the pipe?
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #6 of 7 Old 04-11-2013, 11:18 PM
My test was just an opacity (smoke) test and not a harmful gas emision test like a gasoline engine. I was allowed to have a reading of 30, and I got 5.44, the average was 2.3, so everyone seems to fly through it (cash grab). I've heard that if you can't see smoke coming out the pipe at idle or while driving you will pass. They drive the truck on rollers, so it's not just having a clean idle they are checking for. If you are not hazing while you are driving, I think you will be fine.
However, you never know about the test equipment, I used to have problems with an old gasser truck of mine, 3 different test stations, three totally different readings, including one that showed worse after full tune up and new cat.
Phil
post #7 of 7 Old 04-11-2013, 11:28 PM
Dene2006, I sent you a pm.
Phil
